Normally an increase in compression is accompanied by an increase in torque. I wonder if the bikes for all 50 states have been California'd. That's real bad if true.
It is said the big twins have new cams, perhaps the Sportys do too. Peak torque may be down a little, but it may have a wider spread and be quicker to ride.
Might be right, I do not see the California emissions option listed as a additional cost on the 2014 models, it is listed for the 2013s.
I have no idea why the change in the spec, but this is a very intelligent comment. A high peak torque value is not necessarily a good thing. An ideal torque curve is table flat, meaning the cylinder fill is constant across the rpm range. A table flat torque curve produces a straight diagonal power curve going up and to the right. A setup that pulls hard at one rpm (thus creating a high peak torque value) at the expense of other rpm's is generally less desirable on a street bike. So the peak torque number really doesn't tell you much by itself, it's how it's spread out that matters.
