Rear Brake Bleed Problem
In order to get passed for inspection, I had to change my tires. I figured that while I had the tires off of the bike, I would upgrade the suspension and replace the front and rear brake pads and fluid.
I now have the new tires, Progressive springs and shocks and new brake pads on Talulah. Swapping the brake fluid, however, has been quite the trial.
First, I drained the lines of all of the old fluid, which was probably a mistake. Then I added new DOT 4 fluid to the reservoir. With that done, I started the process of pumping the brake, open the bleeder valve, close the bleeder valve, release the brake. I repeated this on both the front and back until there was clear fluid coming consistently through the bleeder valve, constantly maintaining fluid in the reservoirs..
Well, last night, the front brake worked a little, but not much. The rear just barely worked but only after pumping up the brake 3 or 4 times. So, I tied the front brake lever back and placed a couple of bricks on the rear brake pedal.
This morning, the front brake works just like it's supposed to. However, the rear brake is still mushy requiring 3 or 4 pumps before pads engage, and then the rear brakes just barely work.
I'm guessing that I have an air bubble or bubbles in the line, but it won't work itself out. Does anybody have any ideas about how to void the system of this nastiness?
I was thinking about that, but I really had hoped that there would be a simpler way. Disconnecting that rear caliper and moving the hoses around is such a pain.
We have a winner!
After trying to bleed the system again without success, I did take off the rear caliper and hold it up by the seat so that all of the hose from the master cylinder was pointing up. The second time I bled it, the rear pedal got stiff.
Of course, in order to remove the caliper, I had to remove the brake pads. This really sucked because I then had to put the pads back in after I had bled the system and put the padless caliper over the rotor. Note, I did press the piston back in all of the way, which made it easier to deal with the pads.
Anyway, I took Talulah out for a test and she's a brand new girl.
I was thinking that same thing: most of those brake bleeding tools work some/most of the time. I was tempted to go out and purchase a couple and give it a shot.
Then I got to thinking, "Gravity works all of the time and it's free." I figured that most of my desire to use the other tools was probably rooted in laziness, i.e. I just didn't want to hassle with unbolting the caliper and line.
Anyway, it worked out. Unfortunately, on the ride to work this morning, I lost the front fork pinch bolt and washers.
