screaming eagle vs vance & hines
RE: screaming eagle vs vance & hines
ORIGINAL: 128auto
People always believe on what they have, whatever they own is seemed to be the best, the others are crap. The review is based on his feeling, just like a frog on the bottom of a well, it can only see so much. True enough? By the way, I am happy with my SEII slip-on because they are crap.
ORIGINAL: davidc
????? what is this comment based on? Vance and Hines make some of the best pipes and mufflers availible. I have Vance and Hines pipes on my bike and they sure don't seem to be lacking in the performace dept. I have freinds that have them on a 2006 SE Fatboy, 2006 Street bob, and another friend with a 1200 sportster that had Cycle shack slip on that changed them to VH slip on because he did not like the quality of the chrome and they sounded tinny. When he took them off he offered them to me, but I bought new short shots instead, because IMO the cycle shack mufflers look cheap.
I like my Cycle Shack slipons. Cheap way to add horsepower.Vance and Hines look and soundcool, but lack in the performance department. All depends on what you want. The new SE pipes are crap, stay away from anything the Stealer tries to sell you.
I got the SEIIs and removed the baffled (took about 5 mins- just remove a bolt and pull it out).
Mine are loud as hell- car alarms go off, ppl at red lights roll up their windows, etc... But I really like the look of the short shots so I am thinking about changing.
What about Bassani- anyone have an opinion on their pipes?
Bassani....Well Crager, they look great sound even better but if you ride your bike more than 500 mi a year I wouldn't suggest them. I had a set on my o6 custom 1200, the pro streets. real eye turners but I was tightening and adjusting all the time. The pipes are now in the trash due to the front pipe bracket cracking. After 15000the pipe is almost cracked in two pieces.
ORIGINAL: MikeOK
I would like to follow this thread if you don't mind. I absolutely love load Harley pipes, however I need to keep mine a little quieter. Is there an easy way to get maybe 15-20% morevolume on the stockers? '07 1200N
I used a rotozip with a metal bit to grind off the welds and had to remove the mufflers and use a jack handle and a hammer to knock em out from the inlet side towards the outlet side. Couple of whacks and they dropped right out. You may wanna try drilling the baffles first to see if that is loud enough as knockin the baffles out is a pretty permanent modification. Also if you do decide to fully remove em be careful not to be to overzealous with the grinder as you can grind throuh the chrome easily.
Happy grinding.
I listened to lots of different pipes before I bought mine. The SE slip ons i heard were not very impressive. They were louder than stock, but not by much. I was told that the SE slipons from a couple years back sound better, but harley was forced to tame them down by the government or something. This is just what i heard -- correct me if i'm wrong.
The V&H slipons sound good. The ones i heard were much louder than the SE's. I ended up going with the V&H shortshots though -- they were only an additional $40 over the price of the slipons... and they sound awesome.
