sportster extra plate clutch kit writeup
I pulled the whole cable as I had new o ring already. This really isn't a writeup yet. Was looking for feedback as to make it one or not. For some reason the ? Mark didn't show up in thread title. I will take time to go detailed and make this a writeup when I can. Right now I was just showing pics of the job.
So yes, please make it into a write up. A lot of folks here will appreciate having this documented.
skypeace (10-14-2018)
Received 3,940 Likes
Great start to a write up!
The only two things that were not completely clear to me in the manual was the retaining clip and the tiny little part the clutch cable goes into. I was really careful not to drop that into the primary when putting it back together.
Looking forward to your full write up!
Edited to add- I did not trust the new primary cover gasket not to leak, so I used some gasket sealer...interested to know if you did also, or if you trusted the gasket.
The following 3 users liked this post by slyedog:
Received 4,614 Likes
I wanted my boy to help me. He is 5. Started on it late and didn't have time for him to help. Good to teach them young so they understand how things work. My GPA did this stuff with me all the time. That is why I do my own wrenching on everything. Awesome that you took time to show him.
Another benefit to a fairly early teardown is cleaning the hardware (polish those axles till they slide in by hand) and coating unthreaded portions with grease or anti seize so they'll come out without a hammer next time. I've had to use a small sledge hammer to drive out an axle rusted to that inner spacer, not good. Those swingarm bearings have no seals (I think Harley could have sealed them somehow, design defect to me), and the circlips on the outboard side were really rusty - I coated them with tacky red grease, will see how that holds up. Here's a pic.
I pulled a bunch of bolts and screws, some had some rust on the threads, cleaned that off with a wire brush, put them back, most with some blue loctite, and used a torque wrench everywhere I could fit one. Several were getting loose, and was missing 3 or 4. Might sound like a lot of work, but none of it was really hard (bearing in mind I have the clutch tool, bearing pullers, and a tire changer) and the bike is certainly safer and in way better condition now; I wouldn't be worried about riding it anywhere.
OP, I hope you don't think I'm trying to hijack your thread, just trying to be helpful.
