Front end shake?
Old 03-13-2007, 03:30 AM
skullcrusher's Avatar
skullcrusher
skullcrusher is offline
Default Front end shake?
My 05 883C with 12K miles has started to get a shake in the front end, but only when i let go of the handlebars. I dont notice any difference in handling when my hands even one hand is on the bar. Im wondering if the rim might be bench a little bit?
Old 03-13-2007, 07:46 AM
dbleagle's Avatar
dbleagle
dbleagle is offline
Default RE: Front end shake?
Did you put a new tire on it... loose a weight off the wheel... axle bolts tight???
I think I'd find out what it is... gotta know that's not a good thing... lol
Charlie D.
Old 03-13-2007, 11:49 AM
mejonesrebel's Avatar
mejonesrebel
mejonesrebel is offline
neck bearings need adjusted or replaced probably
Old 03-13-2007, 12:18 PM
SportyPig's Avatar
SportyPig
SportyPig is offline
My first thought was also the tire. If it's the original tire, could have some significant and/or uneven wear going on.
Old 03-13-2007, 01:22 PM
olesalt's Avatar
olesalt
olesalt is offline
That needs attention quick. Could be the rim is not true.
Old 03-13-2007, 03:27 PM
skullcrusher
Thanks. I will be looking further into. It is the origional tire and im in need of a new one. So i'll start with the quick fix's first. Thanks again.
zion
Wheels/Tires
06-26-2012 07:18 PM
mtnroadking
06-06-2012 08:15 AM
edfromptowne
11-30-2008 09:53 PM
bigtop1
05-23-2008 02:32 PM
roadking07
05-20-2008 09:18 PM
Quick Reply: Front end shake?
