Sportster 68540-96 turn signal module
Sportster 68540-96 turn signal module. NFG
XL Sportster 68540-96 turn signal module
When I got the bike it did not have turn signals, but did have the original turn signal module .
I installed aftermarket markers, they do not flash, just stay on and do not cancel.
The brake light work fine as it should.
Thinking the module was bad, I replaced with a so called good unit. Still no flashing of light.
Went thru the wiring schematic, all is good.
Is there a simple aftermarket unit, that flash the signals.
They would not have to auto cancel.
I could make my own harness, with a simple relay and and flasher. Would rather have a plug and play unit.
So called good used units, are $100+/-
Bob
Bob
Can you cancel them manually with the signal switch(es)?
If so, welcome to 1990 and earlier, it's not that bad. A lot of us have been there.
My '91 is the first year with those newfangled self cancelling whatchamacallit gizmo thingys. I still think its black magic.
John
John
