Coil wiring which side Pink wire
Ah, okay. My 2002 manual shows the pink wiring going to terminal 2 (upper right) and the white/black wire going to terminal one (upper left).
The rear spark plug is the lower right, and the front spark plug is lower left.
I was just confused because the stock wiring harness runs those in enclosed plugs, not terminal ends as you have shown. That is typical of an aftermarket ignition module, which may or may not follow the factory coloring scheme.
I was just confused because the stock wiring harness runs those in enclosed plugs, not terminal ends as you have shown. That is typical of an aftermarket ignition module, which may or may not follow the factory coloring scheme.[/quote]
Take a better look at the picture. That is the OEM push on connector. That is an eyelet connector on the wire under the factory Plug !
Take a better look at the picture. That is the OEM push on connector. That is an eyelet connector on the wire under the factory Plug ![/quote]
Took a look on the computer. It's much easier to see than on my phone!
gabarnes28
10-08-2010 03:46 PM
