Do I need a new battery?
Old 02-28-2014, 02:22 AM
hitman1267's Avatar
hitman1267
hitman1267 is offline
Default Do I need a new battery?
This is my first winter that I've had my Forty Eight. I usually keep a battery tender plugged into the battery. My pops unplugged the battery and it stayed that way for maybe more than two weeks. Long story short the bike won't start and wont hold a charge past 11.4 Volts or so. Is the battery kaput?
Old 02-28-2014, 03:39 AM
acrviper's Avatar
acrviper
acrviper is offline
Is the bike new or new to you? I would think it's unusual for a less than one year old battery that has always been on a tender to be shot but it's always a possibility. If it's several years old then it's definitely possible that the battery needs to be replaced and the fact that you leave it on the tender masked the issue for a bit. Either way if you try and charge the battery and it won't fully charge sounds like you need a new one. To be certain you can try and charge the battery disconnected from the bike.
Old 02-28-2014, 03:42 AM
CRocks's Avatar
CRocks
CRocks is offline
Nah, battery's fine, yah need a new dad.
Old 02-28-2014, 04:56 AM
chappy99's Avatar
chappy99
chappy99 is offline
How long did you charge the battery,and what did you use to charge it,and check how much voltage your charger is putting out.
Unless it is a bad battery it should still be good.
Old 02-28-2014, 05:08 AM
Iceman24's Avatar
Iceman24
Iceman24 is offline
Received 2,220 Likes on 1,622 Posts
What are you using to re-charge the battery? Tender or charger? If tender, it won't get battery back to 100%...need to use charger.
Old 02-28-2014, 05:16 AM
hitman1267's Avatar
hitman1267
I got the battery on a tender. Its a new bike, I got it back in July. I need to check the battery with a meter. I am just hoping it wont leave me stranded somewhere.
Old 02-28-2014, 05:18 AM
Iceman24's Avatar
Iceman24
Iceman24 is offline
That's the problem, as I stated, you're trying to charge a battery with maintainer and this won't work...go get a battery charger, hook it up & then the battery will charge. Once @ 100% (12.8V) you'll be fine to put back on maintainer.
Old 02-28-2014, 05:31 AM
deano360's Avatar
deano360
deano360 is offline
+1 get a charger and then see what the voltage is
Old 02-28-2014, 05:41 AM
Peacekeeper6's Avatar
Peacekeeper6
Peacekeeper6 is offline
A few weeks ago, I was psyched to go out for a putt after a long layoff without riding.
I got dressed, got all my riding gear together and pushed my bike out the garage. When I hit the START button, nothing happened.
I had forgotten to hook up my Battery Tender. For a good 3-4 months.
So, I decided to hook it up, and only the red light on the Tender lit up, indicating it was pretty low. I let it charge up overnight, roughly about 10-12 hours. The indicator light turned green, even though I wasn't expecting it to. When I hit the START button, she fired right up.
I say, hook it up to that Tender at least overnight. You never know if that battery may still have some life left without trying.
Old 02-28-2014, 07:38 AM
grbrown's Avatar
grbrown
grbrown is offline
Received 2,851 Likes on 2,419 Posts
Not all battery tenders are the same! Some will recover a discharged battery, others will not. As Peacekeeper6 suggests, leave yours on the tender over a weekend, or couple of nights. If no improvement, get the battery tested, many auto parts stores will test it for you. If it is fine but discharged, either get a better tender, or a proper battery charger.
Quick Reply: Do I need a new battery?
