Screamin' Eagle Stage 1 Air Cleaner Kit
Old 03-22-2007, 10:49 AM
stennml's Avatar
stennml
stennml is offline
Default Screamin' Eagle Stage 1 Air Cleaner Kit
Is this worth the bucks?
Old 03-22-2007, 12:09 PM
dhc8guru's Avatar
dhc8guru
dhc8guru is offline
Default RE: Screamin' Eagle Stage 1 Air Cleaner Kit
I am wondering the same...I would think the reusable filter has go to be worth atleast $50 worth.
Old 03-22-2007, 12:15 PM
capttawes's Avatar
capttawes
capttawes is offline
I've got it on mine and it's fine, I got it for $104 so it was not too bad a price. Some knock it and say there are better ones but most are pretty eqaul from all I've heard.
Old 03-22-2007, 01:39 PM
Tiggeresq's Avatar
Tiggeresq
Tiggeresq is offline
This is what L. Maurice Riggins had to say about the issue:
"You just can't beat theHarley Davidson Screamin' Eagle (SE) air cleaner, which reuses the chrome "ham can" cover. Its filter element has almost twice the surface area of the stock element. There's no other air cleaner on the market that flows nearly as well. Plus, if you ever need to put the bike back to stock, for warranty work for example, you haven't permanently altered the stock components. However, many, if not most, dealers will honor the warranty with the SE air cleaner and slip-on mufflers, particularly if you paid them to install them at delivery or 500 mile checkup for example. Drilling the stock backing plate just gives the dealer an excuse to void your warranty. The SE unit's not much more than a K&N replacement filter for the stock air cleanerand flows a lot better."
Old 03-22-2007, 03:24 PM
1200c's Avatar
1200c
1200c is offline
There is a BIG distinction between the OLD SE and NEW SE. Maurice was talking about the old SE that came with a K&N filter. The old SE filter was all that you needed for the majority of applications and was a fantastic air filter. The new SE is a complete POS that will neither last as long or flow as well. There were about three revision of the air filter. The first ones were falling apart and getting holes in them, while the later ones were dripping gasoline. Either way, they never went back to using a K&N filter as far as I know. Buy one at your own risk.
Old 03-22-2007, 11:23 PM
Booey424's Avatar
Booey424
Booey424 is offline
I agree with 1200c The new SE air filter is junk.It will last on 10000 miles if you're lucky.The K&N filter is supposed to last 10x longer.Why Harley went away from K&N is beyond me.
[IMG]local://upfiles/25674/DDA25C17063A4409B51E8F50AD80FCF5.jpg[/IMG]
Old 03-22-2007, 11:37 PM
Dr.Cool's Avatar
Dr.Cool
Dr.Cool is offline
but you can buy a k&n for it ... correct?
Old 03-22-2007, 11:42 PM
PigInaBlanket's Avatar
PigInaBlanket
PigInaBlanket is offline
ORIGINAL: Dr.Cool
No not at this time.
I have the newer SEa/c and it seems to work just fine for me.
Old 03-22-2007, 11:46 PM
Dr.Cool's Avatar
Dr.Cool
Dr.Cool is offline
ORIGINAL: PigInaBlanket
ORIGINAL: Dr.Cool
I have the newer SE II a/c and it seems to work just fine for me.
no sh%t? So if I need a new filter, I have to goto harley.
1200c's Avatar
1200c
1200c is offline
Have you held it up to the light to check for pinholes?
Quick Reply: Screamin' Eagle Stage 1 Air Cleaner Kit
