my rubber mount lane splitter
power train:
-CV carbed 883
-5-speed sportster transmission w/heel toe shifting
-custom fit Paugcho 2-1 headers w/fabricated rubbermount bracket
-straight piped cocktail shaker muffler/tip.
-heads/cases/primary all hand-brushed w/chrome points/derby/inspection cover contrast
-chrome air cleaner bracket w/chrome louvered mooneyes air cleaner & filter
-speedealer solid brass breather bolts
-DK customs coil relocation w/performance spark wires
-DK customs ignition relocation
-tucked wires
-ledsled customs chain drive conversion w/chrome sprocket & O-ring chain (never oil)
-custom chopped, shaped, & brushed rear sprocket cover
frame/tins
-stock frame w/10" rigid struts
-lowering/sissybar bracket mount
-chopped & shaped fender supports, now rear blinker mounts
-chrome/amber bullet signals w/chrome brackets
-raw steel super narrow ribbed mustang tank w/custom fabricated frame & seat bracket mounts w/duel fuel bungs
-solid brass 90's, T, fuel filter, and shut-off valve w/clear fuel line
-raw steel 6" lowbrow stingray ribbed fender with custom swing arm brackets, chopped to fit
-raw steel haifley bros. sissy bar shopped & shaped custom mounts.
wheels & brakes:
-21" 40 spoked front wheel w/Avon ribbed speed master
-16" 40 spoked sportster rear wheel w/Shinko vintage tread white wall
-heavy duty tubes w/fresh M&B on both wheels
-satin oldschool drilled rotors
-shaved & polished front fork tube narrow glide lowers
-burley front fork tube lowering springs & slammed trees
hardware:
-hippy killer garage solid cast brass rider & passenger pegs
-hippy killer garage solid cast brass shifter pegs
-custom chrome heel toe shifter arms
-hippy killer garage solid cast brass one-off grips
-lowbrow whiskey throttle tube
-chrome clutch lever, brake lever, buttons, & housings
-Kustomtech solid brass spinner gas cap (vented)
-chrome headlight bracket
-custom flipped & amber glassed HD headlight
-chrome carb top
-mini chrome left side mirror
-one-off Zombie Performance squid bars with custom size, bend, drag, and kick-back
-20" wide, 6" tall, internally wired
everything else:
-LaPera pleated seat (solo & king/queen w/sissy bar backrest installed)
-custom hand fabricated sissybar pad, wrapped/pleated by LaPera for perfect match
-noschool choppers 1928 ford duo brake light w/STOP glass & license plate light
-emergency fuel canister mounted under swingarm
-DK customs speedo relocation, custom modified arm & installed off motor w/dummy lights
Received 3,930 Likes
I was looking at all the pics, thinking "that is a kick-*** ride".
Then I saw some DK parts on there. Very Cool! Honored to see some of our parts on a 1-of-a-kind chop!
