5th gear ratio
Old 03-24-2014, 10:50 PM
85RoadsterXLS's Avatar
85RoadsterXLS
85RoadsterXLS is offline
Default 5th gear ratio
My 85 is a 4 speed. So I have always wondered how close my 4th gear ratio is to a newer 5 speed 5th gear. My ratios are 10.00, 7.24, 5.48, 3.97 for 4th.
Old 03-24-2014, 10:59 PM
DeadShort's Avatar
DeadShort
DeadShort is offline
Accoring to HD my 5th on a 2010 XL1200X Forty Eight is 3.517.
Old 03-24-2014, 11:04 PM
85RoadsterXLS
Thanks for the info.
Old 03-25-2014, 05:54 AM
grbrown's Avatar
grbrown
grbrown is offline
Received 2,851 Likes on 2,419 Posts
On my 2011 883 the ratios are: 10.782, 7.702, 5.728, 4.748, 4.071. So what you can see is that the 5-speeds have squeezed an extra ratio in between first and top, otherwise are almost identical to yours.
Old 03-25-2014, 01:08 PM
aswracing's Avatar
aswracing
aswracing is offline
Both the 4-speed and the 5-speed are 1:1 ratio in top gear through the transmission.
The numbers being thrown about here are overall ratios, which includes, primary, transmission, and final drives.
But the transmissions themselves are 1:1 in their top gears, whether the top gear is 4th or 5th. In top gear, the power never goes through the countershaft, it comes straight in the mainshaft and goes straight out the final drive gear. Both the 4-speed and the 5-speed transmissions are designed this way.
flylow5
11-01-2017 06:11 PM
6farmer
09-19-2012 03:31 PM
stevic
08-28-2010 01:41 PM
l.ray
05-05-2008 10:27 PM
O5HOG
18
01-02-2006 06:27 AM
Quick Reply: 5th gear ratio
