Starter solenoid rebuild without removing starter question
Look at my pic that's wear that actually caused a starting issue.. But then the world is full of parts replacers that wouldn't know wear from sicem oops see you made my point already. lol
I call bs on that anyone who actually fixes these knows I am right on with my diagnosis. Just compare the new parts to whats there OP see what you think.
So you would not replace the parts, or even recommend turning the washer over while you had it apart? Remind me to not hire the Car Doc. That starter washer is cratered. Those chrome AM starters aren't worth fixing. But you would know that if you were a Harley starter expert.
I am not a Harley starter expert but I am a Nipondenso starter expert fyi I fix them day in day out. And that washer wont flip for another thing I call bs on. Id love to see a pictorial description of that process haha.
Fact I if you are so sure I am wrong why haven't you posted pics to back your statements up? Post a pic of a bad one and a good one why don't you lets see what is wrong with his washer?
Reason being is a new one will be exactly the same thickness as his is I guarantee it and you know it too.
I have demonstrated my point on the contacts being ok with a pic of an actual bad one.
I am not a parts replacer anyone can do that it takes no skill. Now to actually prove a part is bad thats what you hope you are hiring when you hire a mechanic. my .002
edit: He has a better than 50% chance the starter will work now he has had it apart and messed with all the connections there and at the battery and frame. The odds the starter itself is bad increase exponentially one way or another as to who built it whether it is low quality aftermarket or OE. Bad OE is very rare that is a nearly bullet pruf starter overall.
children, children!!
alright so i replaced the plunger (not the contacts inside the solenoid) and the starter still wont turn over. When i hit the starter button, with my hand on the solenoid i can feel it clicking and engaging, makes noises like the starter wants to turn but then just doesnt. Does this mean my starter is bad? Is there any way to confirm before i order a new starter?
you can test the starter motor by jumping across the 2 big connections on the solenoid with a HEAVY wire (or just use a pair of channel locks like I do), the starter should spin immediately (no starter push button needed)...if it does not turn the connection between the solenoid and starter could be loose or broken... this is more easily done on the bench in a vise....
what I would do is to check and see if the solenoid is actually engaging, I know you hear a click when you hit the button but that does not mean the solenoid is pulling all the way in and the contacts are making, a electric meter attached to the starter side of the solenoid and ground will confirm the solenoid is pulling in all the way when you hit the button (it is the big connection opposite the big connection that the battery connects to)...
Back to sporty starter you could jump the 2 big terminals and the starter motor should run like the guy before me said. Me and him are saying the same things btw.
Or if you had a test light you could simply touch the connection opposite the battery cable (goes to motor) and hit the starter button-if the lite lites up the solenoid is doing its job and yes pull the starter at that point.
Your sure the engine is not locked up right?! And you can back me up here by clearing the air with your feelings on the two plungers they were exactly the same thickness weren't they! Other than a few perfectly normal electric marks around the edges.
No I wouldn't because there is nothing wrong with them like I said earlier his problem is elsewhere read my post.
Are you absolutely certain that your issue is the starter and not the battery...the battery being weak would cause the exact same thing to happen...Oh, and I agree with cardoc. the contacts, including the center ring look fine to me, you might sand the ring a little if it makes you feel better, but I am willing to bet that they are not the issue.....as far as the battery, I would throw a pair of jumper cables on the battery to your car (car not running) and try and start the bike, make sure you put the neg. cable to the frame of the bike (that will eliminate a bad ground for the motorcycle battery)....if the bike starts, I would check the negative ground wire to the frame and have the battery load tested at the store...
