LAF's on my 2014 48.
Yea def let me know about the baffles, I didn't think any would fit. I have torque cones in the heads and still getting some bad decel pop, so I might try doubling up with the dk lollipops. I think I have to keep the head cones think that's the only thing adding enough space to stop the front o2 sensor from getting crushed. Did yours have the 18mm an you get the 12 adapter? If so I imagine they must be in a different spot cause mine are 12mm an there's only a space the size of a hair I can't see them fitting if the ports are in the same spot on the front pipe. Keep me updated I'll msg you if I learn anything.
I orig was getting pipes with the 18 and the adapters but don't remember where the front o2 sensor bung location was. A guy at the shop mentioned they had them with 12mm bungs so I grabbed them. My front o2 sensor bung sits right next to the next to the case in front of the oil filter. W/out the header torque cones the brass sensor was rubbing. I'm going to order 4' baffles today I read a review on JP that said with some finagling they'll fit hopefully with the cones that will stop the decel pop
How are these pipes doing now? I just bought my first Harley (14' Forty Eight) and picked up some LAF Drag Pipes off of EBay along with some torque cones, but am worried about running them with no tuner. They will be my only mods. Will it be okay? I want a really loud and aggressive exhaust, but would rather not jeopardize the health of my brand new bike.
Location: In the foothills of southwestern NC - US of A
Add just exhaust, no need to re-tune.
Add just an intake, no need to re-tune.
Add BOTH and yes you need to retune or at bare minimum go with a set of XiED's to help lessen the previously existing factory lean condition, or just go for the XiED's anyway regardless of any exhaust/intake mods or lack thereof.
The torque cones will help to bring back some of the low end torque you are absolutely going to be losing with those pipes. Loud and obnoxious they will be, until of course you get tired of them and decide on spending your hard earned sheckles on performance items like cams, headwork, 2 into 1 exhaust, a dedicated tuner like the Power Vision, etc., instead of simply making noise
=8^)
