Turn signals: Motogadget M-blaze discs review
Hi Guys,
I got my hands on the Motogadget (www.motogadget.com) M-blaze discs.
Bar end turnsignals.
I had the german company already bookmarked for a long time. I known them for there speedo’s.
For me, finding a good solution to “hide” the front turn signals was a long search, therefore I
want to share this product with you.
I wanted clean, discrete turn signals, so I started looking at bar end turn signals. Most of them were to cheep looking from my opinion, then I stumbled on the M-blaze discs and i gave them a shot:
My experience with the company, the product and the install:
The company:
After contacting them with some questions, I received an answer the next day with a complete and clear answer.
Professional and very kind people that know there product very well !
After a smooth order proces i recuived a confirmation, shortly after this a track and trace number was forwarded to me.
Three days later (I live in Belgium so..) I received the package.
The Product:
The packaging of the products is nicely designed and gives a good protection to the product.
The package includes many different size fitting tools.
There is a clear instruction guide included.
The M-blaze discs looks stunning, simpel and clean design with a very strong and solid costruction.
The wires that go out of the turn signals are very thin ! probable there isn't more needed but I woudend pull on them !
The install:
When using the rubber clamping part suggested as in the instruction manual I wasn't able to slide them in the bars, even when the
nut wasn't compressing the rubber. I started grinding it down, I realised this was going to take to long, so... plan b
I tried with the smaller rubber, no problem at all ! the turn signals are very solid in the bars even with the smaller rubber.
I cut the wires from the oem turn signals to the connector, then I tested them if they work, yes they did.. So then I used solder and 1/3 head shrink to connect the turn signal wires to the old wire+connector.
There was no load balancers needed for my bike (Harley Iron 883 2012 EU version), as suggested already by Motogadget.
the result:
My conclusion:
They look great even with stock grips (Motogadget also has matching grips)
there is more then enough light coming out of them, they are even made in a way they don't blind you.
Pros:
Quality
Overal look
universal fitment
Cons:
Price
The company:
The Product:
The install:
the result:
My conclusion:
Pros:
Quality
Overal look
universal fitment
Cons:
Price
