Replaced Rocker Gaskets, Now No Electrical Power
Hello everyone,
I have a 2007 sportster 1200 and I replaced my rocker gaskets today with no problems but, when I was all done I went to turn on the power to the bike and all I got was the Oil light, a dim neutral light, and a very dim headlight. The horn doesn't work, the odometer is not showing, my fuelpak is not getting power, and I don't hear the fuel pump getting power.
When I changed the gaskets the only plugs I disconnected was the fuel pump connector, the connector that is attached to the wire that goes into the rear cylinder, and the connector for the coil pack.
I made sure the battery has a charge, I then went back and checked all of my connections and they are all connected, i also checked the fuses and there aren't any broken fuses.
If anyone has any ideas and can help that would be great!
Thanks!
Thanks!
brady817bfd
04-20-2014 02:44 PM
