1995 883 uncovered after 13
Old 04-19-2014, 06:46 PM
DrillToDrive's Avatar
DrillToDrive
DrillToDrive is offline
Default 1995 883 uncovered after 13
Recently my dad took his sportster out of his living room for the first time in 13 years. After a near death machinery accident he decided to make time to ride,and put different priorities first. My question is, after sitting all those years is it normal for all the oil to have gone into the crank case? Also after started for the first time, it sounds like a lifter sticks sometimes, or an intake valve is open. As soon as it started to happen, we shut it off. Any ideas on the noise in the top end? Any help would be appreciated. Thanks.
Old 04-19-2014, 07:08 PM
slyedog's Avatar
slyedog
slyedog is offline
Could be wrong but no where for that much oil to go. Sounds like it was low when stored and who knows how much buildup of sludge my be in motor. I would change oil asap and see how it sounds.
Old 04-19-2014, 07:17 PM
DrillToDrive
Already changed the oil with new, that was the first step. After the oil change it grew maybe quarter of a quart. Before this happened the oil pressure light blipped on for maybe a second and then went out. Shut off immediately and started again, this is when the noise appeared.
Old 04-19-2014, 07:49 PM
DrillToDrive
Just went out and started it. The noise is not there, but it's only running on one cylinder. The back rocker cover gets warm in 20 sec. and the front is cool, same with the exhaust. I'm leaning more towards a stuck valve now. Any ideas, yay or nay? Also, anyone know how the lock cylinder comes off, it appears that the lock cylinder needs to come off to take the coil bolt off to remove the coil? Thanks.
Old 04-19-2014, 08:44 PM
run1fsr's Avatar
run1fsr
run1fsr is offline
Have your checked the front cylinder for spark? If not, please do so before pulling anything apart.
Old 04-20-2014, 09:49 AM
DrillToDrive
Yes, the front cylinder is getting spark, it's bright blue, so it's not weak spark. We put new plugs in to rule out a plug that won't fire under compression. It will idle with the choke pulled out all the way, but idles sky high, then it will run on both for a brief second, the idle goes down, then it goes back to one cylinder. If you crack the throttle it either coughs and dies, or continues to run in one cylinder.
Old 04-20-2014, 11:18 AM
cvaria's Avatar
cvaria
cvaria is offline
Received 2,189 Likes on 1,677 Posts
spray some wd40 in the chamber... some jerk talking motorcycle stuff
Old 04-21-2014, 09:44 AM
grbrown's Avatar
grbrown
grbrown is offline
Received 2,851 Likes on 2,419 Posts
If you don't have one, buy yourselves a factory service manual. It has a diagnostic section which may help solve the problem, but will also help you perform any service work or repairs that it needs.
The fact both cylinders fire is promising! I suggest you check simple basic stuff, like main battery and ground connections, disconnect and clean them, along with the LT wiring for the ignition system. There may be a dirty or loose or corroded connector, which isn't functioning properly.
Hey Zeus
Shovelhead
20
05-06-2012 01:31 PM
Go Shovelhead Go
Shovelhead
11-03-2011 09:34 AM
cpotts454
08-15-2010 03:48 AM
rah002
Oil Archive (no new posts)
02-06-2007 02:58 AM
missboy
Shovelhead
12-31-2006 03:10 PM
Quick Reply: 1995 883 uncovered after 13
