06 custom rear wheel
Axle by year:
'08-up both axles metric (25mm) and 6205 bearings.
'05-'07 3/4" front, 1" rear.
'8?-'04 ¾” front and rear - However, taper bearings are used up to 1999 and ball bearings started in 2000.
Check the part #s for the spacers between '06 and '09. Same part #, same spacers. If they're different, they may have different inside diameters with the same length, making for an easy swap. More homework required.
You can heat a hub to remove bearings. Put the new bearings in the freezer to install them into a heated hub. Or, have the old hydraulically pressed out and the new pressed in at your Indy.
You might want to verify outside diameter of the '06 vs. '09 bearings/hub bore before going too far. I don't remember either way about that.
