What Grade of Gas Am I Really Buying?
Received 4,616 Likes
I only use 87 in my 883, but would never put that stuff in my Glide with it's S&S engine. A lot of us have non-stock engines or modifications that 87 wouldn't do well in. My stock engined 1200 runs fine on 91, but I'd use nothing less.
No. More octane is not "better" unless the engine needs it to avoid detonation. He should use what his owners manual recommends and nothing more (unless the only choices are less than the recommended octane and more than the recommended octane, in which case he should overshoot by the smallest possible amount).
Anywhere from 1 cup to 1.5 pints depending on pump design and hose length.
You have a 4.5 gal tank, filling up early when you only need 2-3 gallons only increases the low octane ratio.
Assuming you fill with 4 gallons of 93 and the hose has ~1 pint of 87 octane left in it, the effective octane in your tank will be about 92.75.
Also, bear in mind that the numbers on the pump are the minimum rating for the fuel being dispensed. In actual practice the dispensed fuel is likely 0.25 to 0.5 points higher than displayed on the pump in order for the station to have some buffer zone and avoid potential fines.
For 2006 and earlier (carb) 883's the manual calls for 87 octane.
For ALL 2007 and later Sporties (883 & 1200), the manual calls for 91+ octane.
