What Grade of Gas Am I Really Buying?
Had a discussion with a guy about gas from the pump. He said when you buy gas at a pump that has 3 different grades but only 1 dispensing hose, your first 1 to 1 and ½ gallons is actually whatever grade the person bought who last used the pump. His reasoning is the grade of gas the last person bought remains in the pump plumbing and the hose after the pump is shut off. I always fill up near home with 93 octane ethanol free gas. But usually my bike will only take 2 to 3 gallons. If what he said is true, half of the gas I put in my bike could be 87 octane 10% ethanol formulated gas. He said the only way to prevent this is to find a pump that has a separate hose for each fuel grade. What do you think?
You have a 4.5 gal tank, filling up early when you only need 2-3 gallons only increases the low octane ratio.
Assuming you fill with 4 gallons of 93 and the hose has ~1 pint of 87 octane left in it, the effective octane in your tank will be about 92.75.
I prefer to fill up at 3-hose pumps, but a few years ago I did a calculation on the capacity of a typical gas pump hose (and associated interior piping to the pump) and it wasn't a lot of gas...maybe 1/8 gallon or so. Still, my Ironhead tank only holds 2 gallons, so I'd rather have straight 93 octane in it.
