Installed CVP Premium Carb Kit Bike still runs like hell
2006 1200 custom sportster 7000 miles
Screaming Eagle filter and after market pipes.
Bike sat for 14 months wouldn't start.
This bike ran great before sitting.
Replaced plugs. Drained tank and added a octane booster to new gas. New battery.
Bought a small air compressor and carb cleaner for cleaning the Carb.
Pulled carb cleaned everything but did leave the float installed.
Bike idles great but once in gear sputters/bogs down. If I pull out enricher 1/4 to 1/2 way it runs decent.
So I ordered and today Installed the CVP premium kit. Same problem...
Pulled and cleaned float this time then...
I pulled out the previous jets 42 and 190 replaced with 46 and 185. Also replaced needle, mixture screw, Idle screw, new emulsion tube, replaced vacuum piston slide because (diaphragm torn)and drilled out off set slide hole to 7/64, and replaced vacuum spring.
Set enricher per manual, Set both throttle cables per manual, Ran mixture screw all the way in lightly, and set idle screw till engine almost dies. Then backed out mixture screw from 2 turns all the way to 4 and same problem...
Things I noticed on this carb journey. The previous owner who did all these mods.
- had the needle spaced with 3 washers.
- also the stainless steel (jet nozzle) that sits above the emulsion tube will only allow me to screw in the emulsion tube with the small diameter hole facing up into the carb. Per the instructions this is upside down! But if I flip it the threads are not near close enough to thread the emulsion tube into the carb????????
Thank you for reading and I hope you can offer me a solution. As I refuse to take to the stealership and really want to know how this all work
-GimmeAHammer
-GimmeAHammer
Your bike shouldn't need more than a #45 & #180 jet.
Thanks for replies.
-Float is good as well as diaphragm.
I'll grab some propane and check for manifold leaks first. Then I'll have to get in there again and see why this needle jet doesn't seem to fit the proper way.
Could the previous owner have installed a longer one?
Put everything back together and see how it runs if I still have problems, Ill pull it apart and run the 45/180 Jets as suggested.
Same problem as is "Bike idles great but once in gear sputters/bogs down. If I pull out enricher 1/4 to 1/2 way it runs decent."?
Describe your symptom in more detail if you may. Does it happen when you are cruising? Under acceleration? What does it sound like? Where is it coming from? Does giving it throttle help? Etc.
Also is there any vertical movement in the needle (you have to check very lightly)? There should be absolutely none, not even 1/2 a mm. Since the original needle had 3 washers, it makes me believe that you will have vertical movement. If there is than the needle head can pop up and allow air to get up into the slide and eliminate suction and causing the slide to fall down. Therefore the bike will bog down.
-If there is vertical movement than you have to fix it. I experienced this problem right after installing the CV performance kit myself! I put a very small gasket in-between the needle seat (Plastic white thing that holds down the needle. Spring sits on top of it) and the head of the needle. This fixed my problem!
Problem solved thank you!
The needle jet nozzle I believe is what its called was upside down! The small stainless guide for lack of a better word above the emulsion tube. I flipped to put the emulsion tube on tapped it with a screw driver a few times and was able to get the emulsion tube threaded. Bike runs great now!
Thanks for the advice.
-GimmeAHammer
-GimmeAHammer
-GimmeAHammer
-GimmeAHammer
-GimmeAHammer
-GimmeAHammer
