Primary/Transmission Lube 2012 Mod 48
Is 20w50 Synthetic Oil correct choice for the Primary/Transmission in a Model 48? I have used this in my 2003 RK and it has worked fine. I see mention of
99896-88 Sport-Trans Fluid is this needed or necessary? Is it any better?
Barrier
Barrier
Oh boy, an oil thread.
The straight-up honest answer is that just about anything up to and including 50 weight motor oil will be fine in a primary. Harley's own "Formula+" primary lube essentially tests out as a basic 20w50 motor oil.
Harley's own Syn 3 works just fine in a primary too.
So does Redline's MTL.
So do any number of 75w90 gear oils (note: 75w90 gear oil is essentially the same viscosity as 20w50 motor oil, the two specs use different viscosity numbers).
Basically, you can run even a simple GL-1 rated oil in the primary and should see no problems from it. A GL-3 or GL-4 rated oil should do slightly better, but overall the primary really isn't that picky.
The only caveat is that you should NEVER run a GL-5 rated gear oil in the primary unless it explicitly states that it's OK for limited slip differentials. A GL-5 oil not rated for limited slip differentials can cause your bike's clutch to slip.
Thanks Zenmervolt, That does help. So 20w50 it is. I have some Amsoil Motorcycle oil I will use.
Barrier
Barrier
Barrier
Sorry for the re-post how do I get it deleted?
Barrier
scottycameron
06-04-2013 04:00 PM
