Boring 883 to 1200.
Old 05-19-2014, 11:17 AM
divco13's Avatar
divco13
divco13 is offline
Default Boring 883 to 1200.
What has you experience with Boring 2002 , 883 to 1200, with sizing new pistons to bored Cylinders.
Are the steel liners the same O.D. that are cast in to the Alum casting ?
Pro & Cons
What is the cost of such a job
Old 05-19-2014, 11:34 AM
cHarley's Avatar
cHarley
cHarley is offline
What year bike? 09? and up can't be bored, the jugs have to be replaced.
You can get a complete kit of jugs and pistons from Hammer Performance for around $700.00.
Old 05-19-2014, 11:35 AM
Guzzi's Avatar
Guzzi
Guzzi is offline
Check with Hammer Performance. Seems like they have great reputation here, and a pretty informative website.
Old 05-19-2014, 11:48 AM
divco13's Avatar
divco13
divco13 is offline
Looking for Personal Experience.
Found this on the Web.
http://www.head-quarters.com/html/cylinder_boring2.html
Our cylinder boring and honing has become a mainstay of our business. We think it is because our machinery, measuring equipment and procedures enable us to do an extremely accurate job of fit and finish. The end result is a cylinder that seals well for more power and long life.
All our cylinders are installed in special torque plates. The torque plates preload the cylinders to simulate the same conditions the cylinders would be subjected to while bolted into the engine.
In addition, we use a special plateau honing procedure which greatly reduces piston and ring break in time and eliminates abrasive cylinder materials from contaminating the engine oil.
For 883 to 1200 conversions, we prefer to bore a seasoned stock 883 cylinder to the 1200 size rather than selling a new set of 1200 cylinders. The end result is the very same, cylinder sleeve thickness wise, BUT the seasoned stock cylinder will hold it’s shape better after boring and last much longer.
Old 05-19-2014, 11:49 AM
divco13's Avatar
divco13
divco13 is offline
2002 883c
Old 05-19-2014, 01:09 PM
grbrown's Avatar
grbrown
grbrown is offline
Received 2,852 Likes on 2,419 Posts
You basically have two options, find somewhere local who you can rely on to bore your current cylinders to a suitable set of pistons, or buy a Hammer or similar kit. That kit will come with everything you need, in the same box - simples! Both solutions will use special pistons that can be used with your stock 883 heads, NOT stock 1200 pistons. Depending on where you live in Florida you should be able to find a suitable shop you can visit in person.
HDF Tech
Engine Mechanical Topics
01-19-2024 04:40 PM
jaysxlh883
09-15-2014 05:49 AM
vintagebikes
05-13-2013 09:06 AM
FlyinJ
06-15-2007 12:27 PM
streetbobjim
11-15-2006 06:43 PM
Quick Reply: Boring 883 to 1200.
