New Fat Bob Wheels on 48?
Old 05-27-2015, 07:20 PM
WKNDS's Avatar
WKNDS
WKNDS is offline
Received 1,251 Likes on 924 Posts
Something you may have already thought to check is the
rear caliper & bracket clearance with the tire. IIRC, you
switched to the larger 10.5" rotor/early caliper bracket
and it appears that the 48 in the picture is still using
the smaller stock late-model rotor/bracket.
just a thought....
good luck,
T.
Old 05-27-2015, 07:28 PM
wachuko's Avatar
wachuko
wachuko is offline
Thumbs up
just a thought....
good luck,
T.
hank-hill did switch over to the larger floating rotor like what I have in mine... but I can't tell if he did so after switching to the other set of wheels he installed... I still have the previous setup stored in the parts bin... worst case scenario I will just go back to that setup.
But good catch...
Old 06-11-2015, 06:52 AM
wachuko's Avatar
wachuko
wachuko is offline
Cool
Still waiting for the wheels to arrive... but another 48 owner did the install. In his case, he used two front wheels for his setup. But it gives you a better idea of how the bike will look. Can't wait for mine to come in so that I can finally have that look.
Originally Posted by Wedgey
New pipes, lot quieter than the RSD flat tracker
Rear disc from a '14 breakout, so much better looking than the original disc
same disc as front from the rear of a '14 breakout with a PM 4 spot (pure overkill) caliper
just took them now, only got an iphone for a camera sorry >.<
Love these wheels so much =3
Old 06-17-2015, 03:34 PM
wachuko's Avatar
wachuko
wachuko is offline
Unhappy
Yeah that...
Old 06-17-2015, 03:36 PM
wachuko's Avatar
wachuko
wachuko is offline
Unhappy
Rear wheel is backordered until mid of July... Jon is sending me the rest of the stuff he has so that I can get started with the front.
Old 06-19-2015, 03:56 PM
wachuko's Avatar
wachuko
wachuko is offline
Front wheel is in...
Hub is just a flat cover... I need to paint it black:
I also got the mounting kit from HD... comes with three different air valves, bearings, spacers for different size axles... I guess I will have to reuse the current aluminum spacers...
Old 06-19-2015, 04:02 PM
wiggum's Avatar
wiggum
wiggum is offline
Don't want to wait?
He mentions shipping, not sure if the price is actually good...
http://pennstate.craigslist.org/mpo/5041842902.html
Old 06-19-2015, 05:04 PM
wachuko's Avatar
wachuko
wachuko is offline
Thumbs up
Originally Posted by wiggum
Don't want to wait?
Thank you for the find. But rear wheel is paid for, so I will wait. And it was the same price as that listing.
Old 06-19-2015, 05:09 PM
wachuko's Avatar
wachuko
wachuko is offline
Unhappy
Completely forgot to order the bearing install tool . I will need to stop by the local shop and have them do that...argghhh... or should I just buy the tool:
and then do the install...
Old 06-19-2015, 05:19 PM
WKNDS's Avatar
WKNDS
WKNDS is offline
You haven't said one way or the other, but are you still
planning on using your hubcap? I think it'd look pretty
cool with those wheels (and hide the hub)...
T.
Quick Reply: New Fat Bob Wheels on 48?
