How many quarts for transmission fluid?
Old 06-28-2014, 04:14 AM
Papachu's Avatar
Papachu
Papachu is offline
6th Gear
Default How many quarts for transmission fluid?
just changed my transmission fluid on my 2013 iron 883. But I am not sure if it is enough for my bike, I used one quart of mobile 1 75w90 synthetic. is it enough?
Old 06-28-2014, 05:08 AM
Notgrownup's Avatar
Notgrownup
Notgrownup is offline
Received 6,345 Likes on 3,279 Posts
What dies your owners manual say
Old 06-28-2014, 06:23 AM
Hammerhead Pat's Avatar
Hammerhead Pat
Hammerhead Pat is offline
You don't uses tranny fluid on a sporty, you use a primary fluid such as H-D Formula plus!!! Pretty sure its 32oz, but I'd call a dealer first to make sure.
Old 06-28-2014, 06:59 AM
Riffraff123's Avatar
Riffraff123
Riffraff123 is offline
He didnt use tranny oil. He used "mobil 1 75/90" I assume gear oil. That's fine. You're supposed to fill until it just touches the bottom of the clutch. My 88" 2000 FLSTC took about 1.25 qts. From dead bone dry.
Papachu's Avatar
Papachu
Papachu is offline
6th Gear
I guess I did the wrong thing..I changed the transmission fluid already! What kind of primary oil should I use? Like what brand and what type? And what part of the bike is at?
Old 06-28-2014, 07:04 AM
Iceman24's Avatar
Iceman24
Iceman24 is offline
Received 2,220 Likes on 1,622 Posts
Nice intro too...
Old 06-28-2014, 07:05 AM
Greezey Rider's Avatar
Greezey Rider
Greezey Rider is offline
Received 2,493 Likes on 1,073 Posts
Buy a Service Manual....
I have never understood why guys will start tearing into a service or repair when they have no clue how to do it.
I have been wrenching on these things for 40 years and still refer to a service manual regularly.
Old 06-28-2014, 07:08 AM
Jackie Paper's Avatar
Jackie Paper
Jackie Paper is offline
Received 4,541 Likes on 3,793 Posts
Your Sporty shares the same oil for the Primary where the clutch is and also the transmission. The typical 75w90 synthetic GL5 oil has EP slip agents that may just make your clutch slip and shorten it's life. These agents, also are very corrosive to any bronze type of bearings or materials. You really need to get the proper type of lube from the dealer. Get two. Dump the 75-90 and refill. Drive 20 miles round trip and change it again. No big deal. It's in your owners manual (must have and read) , YouTube and on here . You do not need a service manual for general maintenance but it is a good thing to have if you plan on keeping bike. And also welcome from Hampton Roads Virginia....
Old 06-28-2014, 08:57 AM
cHarley's Avatar
cHarley
cHarley is offline
This is not true for Mobile 1 75w90 that the OP used, I've got over 100,000 miles running Mobil-1 75w-90 in my Sporty primary/tranny.
Your information is only true for SOME GL-5 oils.
Read more about the truth and myths HERE.
And to the OP, your primary/tranny takes 1 quart.
Old 06-28-2014, 08:58 AM
lemonade_07flstc's Avatar
lemonade_07flstc
lemonade_07flstc is offline
Need to have a service manual. One of the first things you should have bought. As Ripsaw said YouTube has videos and I have used them before but I wouldn't personally do maintenance without the manual.
Quick Reply: How many quarts for transmission fluid?
