Primary/Trans and Engine Oil
First of all, there's no problem at all using the HD engine oil in the primary... The reason I bought HD synthetic instead of some other is, you only use ONE qt., and you don't change it that often...
HD says you can use it, my manual says so, it says so on the bottles and I have mechanic friends that ride Harleys, (a lot) that have been using it for years...
I like synthetic oil, and to me, the cost is really is no big deal, at one qt. every 8 to 10k miles!
SR
SR
However, the MoCo currently recommends Formula+ (Gear Oil) for the primary/tranny, while Motor Oil is listed as acceptable. Maybe they learned something?
If you wouldn't think of putting Gear Oil in the motor, why is using Motor Oil in the Gearbox such a great idea?
Yes, you CAN use Motor Oil in the primary/tranny, CAN being the operative word. For several years, after HD Sport-Trans fluid (Gear Oil) was discontinued, and before HD's Formula+ came out, the MoCo recommended Motor Oil in the primary/tranny.
Running a motor oil of JASO MA(2) spec in the primary is perfectly fine, or else shared sump systems would be in big trouble if what you said was true. Stop being so dramatic, and forget about your oh this is what I see when you quote your ignore screen shot. I know you read it.
They were selling a gallon for $7.
Box under the display had 12 qts. in a case. $7
Managed to buy 3 gallons and one case for $28.
When checking out, they had another case of 12 if I wanted it.
When they put it on the counter, said it was a free-bee.
Not bad....
36 qt. containers and 3 gallon containers for $28.
What a sweet deal!
If I change every 2,500 miles, I can go about 100,000 miles!
It's obvious that the MOTOR requires higher spec oil than the PRIMARY, so you CAN use the MOTOR oil in either, but NOT the other way around...
AND, none of my mechanic Harley riders have had any problems from using Harley motor oil in their primary's, and yes I did ask..
IF it was a no no, I'm positive Harley would take it off the cans and say exactly that, in their manuals!
SR
That's very easy to answer...
SR
SR
Use wtf you want, it's your ride.
The technical differences between Motor oil and Gear oil, along with the reasons for choosing one over the other, have been covered here ad nauseam. In fact, there's a whole Oil Section here on the forum dedicated to the topic. I have no intention of explaining it again (for probably the 100th time) just for you.
Thanks for the answer...
SR
