trying to find size for risers.. i have stock 3.3gallon tank with flat 1" drag bars with pullback . what size riser and hopefully can get pullback to go above the tank and also come close to me thanks !!! ride on... rubber down..
On my wife's '13 Iron, I had to use a 4.5" riser to clear the tank.
I tried 3.5", but the pullback hit the tank. I used Drag Specialties
from amazon (only because it was easy). Link is below picture.
thanks for the help and even a link . i order 5-1/2 with pullback so hope there not too high now after u saying go with 4.5" . i get them mon or tues so see how it is lol . those irons are cool. heard the fat front tire rides nice
On your wife's Iron, did you have to get a longer brake line? Do you have any pics? Curious about doing the same thing.
No just bent the hardline a bit & moved the line at the clamp point up
out of the clamp. I used a zip tie around the hardline and clamp to
secure it.
I don't have any recent pics. I'm currently in the process
of adding a righthand rotor & XR caliper. Already got the RH
slider (and Intiminators with rebuild kit) done. I'll try to take
some pictures when its all completed (along with the larger
rear rotor).
