98 Won't Turn Over
Old 07-22-2014, 05:54 PM
98SportsterCD's Avatar
98SportsterCD
98SportsterCD is offline
Stage II
Default 98 Won't Turn Over
I have a 98 1200 Custom and I haven't been able to get it to start for about a month now. Any suggestions gladly welcome.
Bike wouldn't start. had no power like the battery was dead, starter switch did nothing. Turn signals, horn and brake lights worked
Headlight did not.
replaced the hand control switches (thought starter switch might be bad)
replaced all 4 fuses
replaced ignition relay
replaced headlight bulb
jiggled something and bike started but turn signals and horn did not work
after I turned it off the bike tries to turn over but won't, all lights including headlight work but no horn
had battery test (was good)
now no spark at spark plugs.
Ordered new battery cables and need to test if power is going to the coil or if the problem is with ignition module. Also replacing vacuum tube from petcock, and elbow joint from other side of tank.
previous work:
replaced battery
replaced the ignition module with the Ultima Programable Ignition
replaced the stator
replaced the voltage regulator
replaced horn
misfitJason
Electrical/Lighting/Alarm
11
04-19-2018 07:35 PM
Matt Payne
06-25-2017 01:44 PM
98SportsterCD
07-22-2014 07:50 PM
TurdTech
05-21-2011 09:55 PM
Sid5748
08-02-2008 11:27 PM
Quick Reply: 98 Won't Turn Over
