new handlebars and bending front break line
Hi,
I'm putting my hand controls back on after installing some biltwell frisco bars on my 02 sporty and I need to bend the front brake line (metal part) near where it attaches to the master cylinder since that section is too long.
1) Should I have any issues with bending the line as long as I'm careful?
2) Can I loosen the banjo bold holding it on to rotate the line forward so I only have to bend it once, instead of into an S curve? I mean if I do that will I have to bleed my brakes or anything like that?
Thanks!
Thanks!
You shouldn't have any issues bending the brakeline. This is what I did:
1. Loosened the banjo bolt but didn't take it off.
2. Then bent the brakeline slightly carefully into a crooked straight line by hand.
3. Then pulled the brakeline up to fit the higher bars.
4. Tested the Front brake for operation.
4. Tighten everything back up.
All done with exactly $0 spent on the new brakeline for the higher bars.
I put chumps on mine (6 1/2" rise, 6 1/2" pull-back) and the line was so tight that I couldn't even mount the brake lever assy. I bit the bullet and bought the cable kit. I got away with re-routing the clutch and throttle cables but, I ended up using the brake line from the kit. I still have the cables for when I may need them.
Buy the brake line
Buy the brake line
I got the ones for 12" apes. It was the shortest kit I could find on J&P. It even came with extensions for the wires if needed.
The brake line was just right fit and I think nicer than the original in appearance.
Burly XL cable kit
Burly XL cable kit
