Best slip on exhaust for sporster?
Hey Robert,
What sounds good to one may not to another.
If you get the Straight Shots, get a set of Thunder Torques Inserts, it will drop the tone a bit deeper AND will give some extra low and mid range power...those pipes tend to have a dip in the low and mid range.
Give a listen to these...certainly "cheap", plus you'll have a nice gain in power.
Converting Stock Harley Exhaust Slip-ons - YouTube
Another option is to build your own...not terribly expensive with an Exhaust Builders Kit, may have the sound you like, plus it will be a look you like (since you can do anything you like) and you can get some really good power out of them.
Here's my Sporty with my take with the Exhaust Builders Kit.
Received 3,960 Likes
No, there is no tuning change required when using the TTI's. They increase the exhaust gas velocity in the exhaust tract, reducing reversion so that the exhaust is not working against the engine.
__________________
Kevin
Gear Up & Ride in! DK Custom 4th Annual Open House, June 8th. 🏍️ Click HERE For The Lowdown.
DKCustomProducts.com
Kevin
Received 71,051 Likes
