Hey guys, did a search but all I saw were threads on adjusting the clutch which is not what I want to do. I just want to move the actual grip down a bit as it sits a little high. From what I can tell it's just 2 torx screw's and it should be movable. Anyone done this?
Yes, you can adjust the levers, but the switches will need to move with the levers too. The levers are keyed into the switch housings, so they will have move too.
Yea, I loosened the 2 torx bits that I thought would move it....not so. I think there is a 3rd one on top of the handle that I also need to loosen.
