Replacement Speedo/Tach for an Iron 883
Ok, I'm looking for a dual side-by-side Speedo/Tach that will fit the Iron 883. Done a ton of work on mine and I HATE the single speedo. Anyone done a swap or know of a replacement that will fit? I know there is a combo by HD that has a digital option, but that is still a single gauge.
thanks.
thanks.
Tach in the side of the tank
I'm thinking of buying this kit for my 2012 Iron, but will not use the dual bracket, instead I think it would be cool to place the tach in the left side of the fuel tank using a different bracket, and leaving the speedo in it's original single position. Anyone has done that already? If so, please post some pictures. Do you think I can order only the tach and the wiring instead of the entire kit? Thanks.
