Crankcase breather puking
Hey all. I've got a 2000 sportster 1200 with about 16750 miles. About a week after buying it I replaced the air filter, I did the oil and filter change day one. Well a week later I noticed the puking. It's not enough at idle to notice it but you see it on the right side of the bike after a ride. I pulled the oil pump which looks good. Second thought is the rod that turns the pump. I didn't notice any wear or shavings on the pump that might indicate it though. Could the air filter or breather be clogged causing this? Possibly just a bad return hose? I did have to cut the old one because it was solid on the pump.
Appreciate the suggestions or return questions.
