streetglide shocks ?
Old 08-01-2014, 12:23 PM
ryanlberg's Avatar
ryanlberg
ryanlberg is offline
Default streetglide shocks ?
will any year streetglide shock fit my 2014 48. I just want to double check
Old 08-01-2014, 03:18 PM
liljoejoe54's Avatar
liljoejoe54
liljoejoe54 is offline
I'm pretty sure any year will fit but just in case, try getting a set close to your year. I bought a set of aftermarket street glide air shocks for my '13 and they bolted right up, I just had to put a couple washers between the shock and frame at each mounting point to ensure the shocks won't rub anything.
Old 08-01-2014, 04:10 PM
gar187er's Avatar
gar187er
gar187er is offline
just about any year will fit...you might need to get some spacers (washers) so the shock doesnt rub against the strut support.
get the newest/lowest miles ones you can find.
HUGE improvement over stock!!!!!!!
Old 08-01-2014, 05:49 PM
Ployd4's Avatar
Ployd4
Ployd4 is offline
https://www.hdforums.com/forum/showt...2510&styleid=9
Great thread to read. It helped me find the correct shocks on eBay. I got the 54662-09 street glide 11.5"
Old 08-03-2014, 06:11 AM
Mick's Avatar
Mick
Mick is offline
Starting in 2009 , all the 12" electra glide "type" rear shocks are valved a bit stiffer than the previous years due to the frame change. So they will offer a bit more dampening control.
Mick
Old 08-05-2014, 03:19 AM
RickRock's Avatar
RickRock
RickRock is offline
Looking to switch to street glides (11.5"- 54662-09 or 12" -54662-02A) also on 06- xl1200c. I'm concerned about them being too stiff because rider weight is 135lbs and these shocks will be coming from bigger bikes. Thanks for the info on the subtle differences and your help Mick.
Old 08-05-2014, 06:01 AM
Rog48's Avatar
Rog48
Rog48 is offline
Yes they will be too stiff, @ 165 they were too stiff for me. Hell the 13" ones were too stiff for me, well.........no better than stock. 13s with lowering blocks made them a little better than stock.
Old 08-09-2014, 12:24 PM
Kipp8302's Avatar
Kipp8302
Kipp8302 is offline
glad to know this does work. i found a cheap set on cl i was gonna pick up but wanted to make sure it would work first. i need something to make the ride smoother with my wife with me. and possibly lift it slightly so i can put some bags on it ('14 iron)
Old 11-23-2014, 07:15 PM
OddJack's Avatar
OddJack
OddJack is offline
I am searching threads about air shocks for 48.
isnt 11.5" too short to have any noticeable difference in the ride?
Cdal1
05-10-2016 11:31 AM
armydgp
10-06-2015 09:27 PM
iwillfixthem4u
08-20-2012 05:01 AM
JimmyDee
02-17-2012 09:49 PM
Garemlin
08-19-2009 05:39 AM
Quick Reply: streetglide shocks ?
