Tubeless tires for spoke wheels?
Old 08-23-2014, 01:11 PM
iDc's Avatar
iDc
iDc is offline
Default Tubeless tires for spoke wheels?
I recently bought a set of shinko 777 tires and found out they were tubeless. Is it possible to add tubes to them, if so, is it difficult to where installers will charge extra?
Thanks
Old 08-23-2014, 02:33 PM
cpracing519's Avatar
cpracing519
cpracing519 is offline
You can use tubes in tubeless tires. They say tubeless but for mag wheels only. My avons say tubeless also but when running spoked wheels you need to add tubes.
Old 08-23-2014, 02:55 PM
cHarley's Avatar
cHarley
cHarley is offline
Thanks
Yes, if you have OEM wire spoke wheels, you need tubes.
Tubes should be replaced with new ones when you change the tire, so you need to buy them.
I've never known anyone to charge extra labor for doing a tire install with tubes.
Old 08-23-2014, 08:34 PM
Roni's Avatar
Roni
Roni is offline
Not only will you need tubes, but you should also get rim bands. Without those, your spoke nubs in the rim will rub a hole through your inner tube in no time.
Old 08-23-2014, 10:58 PM
Wrenchy's Avatar
Wrenchy
Wrenchy is offline
Rim bands and tubes are always replaced, at least at the dealer I work for, when changing tires on a spoke wheel.
HDJIM1158
12-01-2018 10:20 PM
hyrax222
EVO
13
03-03-2015 08:52 PM
steelpix
06-08-2014 09:34 AM
workformetoo
08-25-2010 03:32 PM
BEN-Z
08-07-2009 11:33 AM
Quick Reply: Tubeless tires for spoke wheels?
