Derby, Chain Inspection, and Timer Cover torque specs ???
all here:
https://www.harley-davidson.com/en_U...ER/file-7.comp
register your bike and you'll find all this stuff there.
here: http://www.harley-davidson.com/conte...me/owners.html
>> sign-in / create profile (upper- right hand corner)
https://www.harley-davidson.com/app-...ER/file-7.html
NEW Torque SPECS:
Chain Inspection Cover: 90-120 in/lbs. (10.2-13.6 Nm)
Derby Cover (Clutch Inspection Cover): 90-120 in/lbs. (10.2-13.6 Nm)
Footrest Bracket Bolts: 45-50 ft/lbs. (61.0-67.8 Nm)
He guys I found a couple of people that have had their Chain Inspection Cover threading break on the actual case so I figured I give everyone a heads up in case you are following the HD Specs of 90-120 in/lbs. BE CAREFUL when using these specs as it can cause the thread portion to break. I found this link http://xlforum.net/vbportal/forums/s...d.php?t=607355 that someone else shared on the forum for those that like to torque things to specs like me. Torque these screws to the 40-80 in/lbs setting as it says on the link.
