New 48 Battery Cover popped off
Hey guys, I've seen some posts in regards to other bikes. Wondering if there is a updated fix besides zip ties. I was lucky as the cover didn't fall completely off. The bottom hook held it. But when I pushed the cover back on it doesn't seem to snap in place. I don't feel confident that it will stay. I'll probably head to the dealer but wanted to check here first to see if there is something easy I can do to fix it,
Mine did the same thing. Since it was new, drove it to the Dealer and the mechanic took a look and showed me where the wire was not allowing it to stay closed. He did some rearranging and its been fine since. They've had this happen quite a bit - some need clips, others its wiring in the way.
Thanks guys, I took it to the dealer and they replaced the front clip. I think it's just going to happen again though because the wires have rubbed some of the paint off and I believe that's the problem. I didn't have time to stay and have them rearrange the wires. I'll probably take it back soon though. Thank you for the replies!
Why not just do it yourself at home? Just play with the wires, reroute what you can for a neater tuck and it should be good. Less time than going to the dealer.
I know this thread is old but thought I'd share a quick fix I used yesterday after a shower thought.
I used an old waist belt to secure it. I like the way it looks too. I'm a 34 waist and it fit like a glove.
No drill just my hands the belt and a needle nose pliers to aid in threading the belt through the frame and under the seat.
Old waist belt to secure battery cover on Sportster.
