10" mini-apes clutch cable
Received 3,940 Likes
You should be able to run the stock clutch cable, just re-route it so it's not going between the forks.
If you don't have the stock cable, I just went and measured mine, it's 58" long and I'm running the mini-apes with 2.5" riser extensions. The cable goes down the handlebars and along the downtube, and then under the primary cover. 68" will certainly work, but why buy one if you still have the stock one?
Yep, that is essentially what I did. I looked up the length on the Seventy Two and it's 68". Ordered it today on my way home from class and pick up up tomorrow. In the mean time I got the switch wires and throttle cables re-routed and everything set just waiting on the clutch cable.
ConeMagnet
09-03-2014 07:54 PM
