Certain years of Sportys to stay away from? Shopping used for the wife....
I've heard of some stators needing replacement around 40k, but there is some debate on weather or not it is caused by using the "wrong" type of oil in the gearbox. For a while there were some bad voltage regulators on the early rubber mounts but that would have probably failed by now.
Other than that, just minor stuff, like the battery cover side plate is prone to come flying off (clips are not the greatest). The fuse holders are known to allow water to get in and corrode the connections.
My '06 is virtually the same bike, I wouldn't be too worried about the mileage. I'm at just over 20k with zero issues.
I would read the thread on checking for trouble codes and use it to check out any bike you look at. Not that you would have to know what the code means, but at least to check if it's throwing an error code. 9 times out of 10, for me anyway, it's a loose battery connection, but it wouldn't hurt to add that to your checklist when looking over a Sportster.
Received 4,105 Likes
Thanks to all that contributed...ended up bringing home a bike this past Saturday.
Posted in this thread here...got a great deal on a repo'd '04 1200Custom.
https://www.hdforums.com/forum/off-t...he-stable.html
Shameless CL plug
http://atlanta.craigslist.org/sat/mcy/4660222995.html
And Ebay plug...........reserve is less than $3900
http://www.ebay.com/itm/261594110868...84.m1555.l2649
You cant go wrong with a 2000-2003 XL1200. They are available on Craigs list and most are really solid bikes. Easy to finds parts for and for the most part start em up and go. I have a 2002 with an S&S super E and my bike starts right up everytime. No sputtering. No stalling.
Just my two cents.
Just my two cents.
