New Member with Blinker problem
Old 09-03-2014, 01:38 PM
95Sporty883's Avatar
95Sporty883
95Sporty883 is offline
Stage I
Default New Member with Blinker problem
Hey guys,
So I recently bought an 1995 883 Sportster. My first Harley....switched over from Jap bikes. I'm not too good with electrical work and don't have a manual yet and was wondering you guys could help me.
So right now my bike only has rear blinkers, and they dont blink. They light up fine as driving lights, but don't blink when I hit the blinker. I have sort of read around and seen that you might need all 4 blinkers getting power for them to work?
Any simple way around this? right now I have the front blinkers wire crimped on one end and empty on the other end, waiting for front blinkers if I decide to add them.
Thanks for any/all advice and recommendations.
Also to add, I have checked the switches and them seem to be wired fined.
Old 09-03-2014, 02:33 PM
ChickinOnaChain's Avatar
ChickinOnaChain
ChickinOnaChain is offline
Big Kahuna HDF Member
Received 3,070 Likes on 2,554 Posts
Your question didn't belong in the "New Members Area".
It's for introductions. So it was moved in one of the other forums.
Old 09-03-2014, 03:08 PM
del P's Avatar
del P
del P is offline
Stage III
One thing you can try is buy led load equalizers and wire them into the front blinker wires. They are resistors that create a draw equivalent to a standard bulb. That should give you your flash back
Old 09-03-2014, 11:08 PM
Skellig's Avatar
Skellig
Skellig is offline
Speaking of bulbs... I bought a new Iron 883. Wasn't until a couple days later I noticed I didn't have any running lights but the turn signals worked, kind of the reverse of you what you have. Since it's a new bike I had to let some steam vent and then went to the dealership the following weekend and they had the wrong bulbs in the front, as they built it custom before anyone bought it. By putting the correct bulbs in the whole system, front and rear worked as per normal. Keep it simple if that works.
Old 09-03-2014, 11:55 PM
Greatscott's Avatar
Greatscott
Greatscott is offline
If nobody comes along to answer your question here, I would recommend going over to xlforum.net and check out the electrical section. Tons of technical info and very knowledgable folks over there.
Welcome
Old 09-04-2014, 12:32 PM
mrfikser's Avatar
mrfikser
mrfikser is offline
you are correct about needing 2 lamps for the lights to flash, you may be able to get around this with a different flasher relay or brighter bulbs, but I don't know which ones would work..the problem is that just one bulb does not draw enough current to cause the relay to heat up and open the circuit causing the flash...you might be able to use something like car reverse lamp bulbs which I believe are brighter than turn signal light bulbs...but hen you have to watch that they don't melt the socket...
ggadwa
11-10-2015 06:11 PM
schnorrbusch
05-24-2014 04:35 PM
Long124
05-16-2013 11:48 AM
89Sportster1200
10-07-2009 12:05 PM
jl28
06-19-2009 06:09 AM
Quick Reply: New Member with Blinker problem
