DELPHI troubles, again!
My money, my bike,you know...
It has for now 45 k miles on it since I bought it brand new in march 2012. Always has been maintened by this indy, but the guy is more happy when he doesn't see me, I thing...
This is why I'm kind of pissed for now. While being not sure the nearest H-D dealer would be up the Task. This is Europe here...
Ok Guys,
I checked out any connections to the injectors, there is nothing loose, no wire twisted nor bad looking.
I pulled out my coils, to check them following this method:
The measurement between pin A to C and between pin A to D shows an infinite reading, full open, while I should have 0.3 to 0.7 Ohms.
Measuring between the two HT exits to the four pins shows only a reading between those exits and pin B, reading is 0.9 Ohm.
Coils went south I guess, but my question remains: Why does the front cylinder goes well and the rear cylinder gives nothing at all? Weird stuff going on here...
Ok Guys,
I also checked the HT wires, the front reads 200 ohms, the rear 600, a slight difference...
I'll order a new coil and two wires, will also have a look at a coil relo, I think the rear HT wire is too exposed to the heat of the engine...
And if this doesn't solve my problem, Ill be there again calling my bike a big POS...
