2014 Sportster 48 Throttle Sticking
Okay so I know that the tension screw and binding cables are the usual suspect here with a sticking throttle but I can't seem to figure this out.
I backed the tension screw all the way out to make sure its not catching anywhere on the throttle cable. Throttle still sticks.
I traced the two cables down into the engine to make sure it wasn't being pinched anywhere and its not that I can tell.
This is exactly what its doing: When I twist the throttle to give a little juice, it sticks, or holds in that position. When I then let off the throttle, it stays there until I twist it back/return it into the "no juice" position.
I didn't do anything crazy recently, I swapped my bars out awhile back but this didn't start happening until this morning.
PLEASE HELP!
PLEASE HELP!
star nut
I took the star nut off all the way (cant say I would ever use that dangerous ****). Still sticking. Cord is not binding anywhere in the switchhousing/grip.
I loosened up the tension on the throttle cable and bam, fixed it. Very strange though, the nut on the cable was tight and remained tight until I loosened it.
Not sure how it increased the tension by its self. Hopefully some freak thing.
Thanks for all the pointers guys!
