Fork Oil Weight?
According to Amsoil , Harley type E fluid is comparable to 10wt fork oil.
The next weight down is usually 7wt or 7.5wt.
I recently picked up some BelRay 7wt which I'm going to try in my 48.
If you're a big guy , 10wt might be about best , but 7wt would be worth a try.
Generally 5wt will cause a bounce with standard dampers for most riders.
If you have never serviced the forks , anything might work well , as they usually have metal and gunk from the initial break in miles.
I used screamin eagle fork oil in my Ultra a couple years ago as a quick way to slow down fork dive on very hard braking , the SE was suppose to be equal to 15wt.
Mick
Mick
This argument is about to be settled for good...
The front fork fluid is a proprietary formula that honestly is not 100% matched outside of Harley Type E. The closest viscosity specs would be approximately a 7.5W fork oil.
You will never be satisfied with the damping rod forks. They utilize orifice flow, which is a compromise. Heavier fork oil will give you less dive, but it will be a harsher ride. Lighter oil will induce more dive, but will give you a smoother ride.
mrbreezeett1 (02-28-2020)
I have used 5 and 7 and am going to 10 as front dive is still a big problem.
I am also trying 10 wt Amsoil Shock therapy with ATF with transmission fluid with seal fix in the rear shocks (as I have a leak), Their Showa's 13" air adjustable so I can swap out the fluids at will. see:
https://www.hdforums.com/forum/touri...oday-pics.html
and
https://www.hdforums.com/forum/searc...rchid=26231741
Any real riders will want to take note as the ride is vastly, vastly improved with Shoaw's, the absolute best $50 I ever spent.
and
I'm going back to 10 weight and am going to add 1/2 inch pre-load.
John
