2008+ 25mm Axles
2008+ 25mm Axles
Used front 25mm axle 43895-08 and a New rear 25mm axle 41176-08...bought specifically for 08 Sportster wheels. May fit other models, check with your dealer.
Bought for a wheel swap that didn't happen. Rear axle fits Sportster swingarms from 2005 up as they are all 47587-05A. Allows you to install a wheel with 25mm hub on 05-07 Sportsters with 1" axles. As far as the front goes, you would need to change your lower fork legs to 08 and up 25mm axle.
Used front is $25 plus shipping, new rear is $50 plus shipping.
Thanks...
Thanks...
