Mark this thread as Unsold
Sportster Chopped Fender Kit
This kit has literally everything you need to swap your full fender for a harley oem chopped fender. I purchased all this for my 04 Roadster and hadn't gotten around to installing it, my wife now rides that bike and prefers the full fender with the brake light
all parts included are oem harley parts
Price is less than this stuff is worth separately and will give you a complete, fully serviceable fender on your bike
Parts:
Fender - 07+ chopped fender with hole. I welded in a panel to fill the hole meant for the ecm as this was going to go on my 04 1200R which has no hole, 2007-2009 sportsters will need to cut out this patch panel but 2004-2006 or 2010-2017 can leave it in place and keep road grit off the bottom of their seat (why i patched it). you will have to reuse your fender brace like i was planning on doing as this fender does not come with one. Fender was rattle canned with primer and 2 coats of color match vivid black paint, not a perfect job but not awful either (more pictures available on request)
Reflector Brackets - 68704-07 and 68857-07 - these are brand new never installed, purchased them to fill in the open slots on the side of the fender, they do not include the reflectors as i was going to cut off the spot that houses them so no part of them sat below the fender
Side Plate mount - 67900115 plate mount for a softail slim with integrated plate light and wires with male pins. sits on a shortened left standoff (included) and folds up if you ride too close to something
Gloss Black standoffs - in like new condition, includes the shorter left standoff so once the plate mount is on they look the same length
all pins and connectors needed to do install and have fender removable without cutting wires, just like from the factory
73190-96 (10) Male pin
73191-96 (6) Female pin
73152-96BK (3) 2 position Male Plug
73102-96BK (5) 2 position Female Plug
you'll need to crimp these pins, i have the harley crimper and was planning on using that but you'll have to use your own, other brands will work as well, when crimped the insulation is crimped as well as the stripped portion of contact wire
Auxiliary Brake Light/Running Light/Turn Signal Kit - 69463-06A for 2004-2013 sportsters, not sure what else would be needed to make it work for later bikes
Wire and Heat shrink - black, white, red, brown, blue, violet wire. all correct gauge and much more than needed for job, 5' of heat shrink. Also included the wiring diagrams needed, pretty simple install if done slowly and carefully
Price $450 shipped to Continental USA open to best offers but if its lowball I'll go to Feebay with this kit
Feel free to ask any questions you may have and I'll do my best to answer them
Parts:
