Vied
Vied
used for 200 miles( actually 179) $87 shipped
Plug-n-Play Fuel Management Upgrade
For
Harley-Davidson
The Plug-n-Play ViED richens the Air Fuel Ratio from14.6:1 to a range of 14.3-13.9:1 in closed loop mode.
This Variable Fuel management upgrade allows you to fine-tune the air fuel mixture with a small screwdriver.
Immediate Benefits:
Lower Engine Temperature
Lower Exhaust Temperature
Improved Throttle Response
Reduced Surging
Reduced Pinging
Recommended for:
Stock Configuration
High flow air cleaner
High flow exhaust
"Stage 1" (both high flow exhaust & air cleaner)
The ViED's are a cost effective alternative to an aftermarket tuner & dyno runs. ViED's will cool your bike down and make it run better.
Fitment:
Touring 2007-2009
Softail 2007-2011
Dyna 2006-2011
Sportster 2007-2012
V-Rod 2007-2011
For
Harley-Davidson
Immediate Benefits:
Reduced Surging
Reduced Pinging
Recommended for:
Stock Configuration
High flow exhaust
Fitment:
Touring 2007-2009
Softail 2007-2011
Dyna 2006-2011
Sportster 2007-2012
V-Rod 2007-2011
