FS - Custom Dynamics Sportster XL lighting modules - $65 shipped in Lower 48 states
These are take offs from my wife's Sporty. We installed Custom Dynamics LED Turns signals in July. We just traded the bike on Friday for a Softail. What I have are the Run / Brake / Turn module (Gen-Smart TPU - XL) and the Standard Signal Stabilizer module (Signal Stabilizer- XL). The Run / Brake / Turn sells new for 89.95 and the Signal Stabilizer sells for 64.95. Not supplied are the LED Turn Signals (which are available from Custom Dynamics). The complete package (including LED's) was close to $300. With these 2 modules, you can put the system together for a fraction of that.
Asking $65 shipped for the pair.
Here are instructions for each module, along with a link to the CD site:
http://www.customdynamics.com/instru...le-play-xl.pdf
http://www.customdynamics.com/instru...er-xl-fuse.pdf
And............
http://www.customdynamics.com/tailco...Load_Equalizer
And............
Harley Davidson
This module triples your visibility in the rear.
SMART Triple Play® Features
- Converts Rear Turn Signals to Run-Brake-Turn
- Works with LEDs or Incandescent Bulbs
- Choice of 10 User Selectable Built In Brake Light Strobe/Flash Patterns (User can also select no Strobe/Flash on Brake)
Pattern 0: Four Flashes then Solid (Incandescent or LED)
Pattern 1: Four Flashes, Solid for 3 Seconds, Repeat (Incandescent or LED)
Pattern 2: Seven Flashes then Solid (Incandescent or LED)
Pattern 3: Seven Flashes, Solid for 3 Seconds, Repeat (Incandescent or LED)
Pattern 4: Quad Strobe, then Solid for 1 Second then Quad Strobe (LED Only)
Pattern 5: Quad Strobe, Solid for 1 Second, then Quad Strobe, Solid for 3 Seconds, Repeat (LED Only)
Pattern 6: Custom LED Blaster X Cycle for 3 seconds, then Solid (LED Only)
Pattern 7: Custom LED Blaster X Cycle, Repeat (LED Only)
Pattern 8: Max Strobe 4 Seconds, Solid (LED Only)
Pattern 9: Constant Max Strobe Pattern (LED Only)
- Ability to apply Brake Strobe/Flash Patterns on Center Taillight only, Rear Turns Only, or Rear Turns & Center Taillight
- SMART Function - If Brake Strobe/Flash is Turned On, Strobe/Flashing will be paused on Turn Signal if Simultaneous Braking and Turning
- 10 User Selectable Running Light Intensities Allow User to Match the Running Light Brightness of Turns to Center Taillight
- Built In Short Circuit Protection
- Sealed, Weather Tight Case
- Slim Line Design: 4.2" x 1.4" x 0.6"
