Harley Davidson Forums
Harley Davidson Forums - Harley Davidson Classifieds - HDForums.com Photo Galleries - Create an Account - Harley Davidson News
Go Back   Harley Davidson Forums > Do It Yourself Help Forum > Tech Tips
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Tech Tips Tech tips as they become available.
Welcome to HDForums.com!
Welcome to HDForums.com.
Thread Tools Search this Thread
Old 07-25-2005, 11:48 PM
HDF Tech HDF Tech is offline
Default Low Fuel Lamp
June 21, 2004
Low Fuel Lamp On EFI Models
Information on low fuel lamp diagnostics was inadvertently omitted from the 2004
Manuals. The low fuel lamp should turn on when the fuel level is between .7 and 1.3
gallons. Whenever checking proper lamp ON-OFF operation remember all of our EFI
model fuel gauges have a software filter that limits the lamp reaction when the ignition is
ON. This prevents lamp flicker under hard acceleration and braking. Each time the rider
turns on the ignition switch the software filter is reset to the current fuel level value.
When diagnosing a fuel lamp issue the float must be positioned while the ignition is
OFF. When ignition is turned ON, proper light response can be verified. If the low fuel
lamp is lit, and the float is raised either manually or by refilling the fuel tank while the
ignition switch is ON, the light will not go out for quite some time. Simply turn the ignition
switch OFF-ON to reset.
Similarly, if there is enough fuel for the low fuel lamp to be extinguished and the float is
either bottomed manually or the tank is drained with ignition ON, the lamp will not light
for quite some time. Simply turn the ignition switch OFF-ON to reset.
Source: http://www.harleyhog.co.uk/
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on HD Forums!
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
Vendor Directory
New Sponsors
Advertising Information - Harley Davidson Forums - Archive - Top
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0
