**INSTRUCTION SHEETs**
This is a back-up copy; synchronized 02-14-2010
click HERE for ***H-D instruction sheets database thread***
Greetings to all of you!
As a member of this forum I would like to share some information on H-D instruction sheets with you.
Below you will find a database I was able to set up with the help of mud
** posting #1 shows the parts in numerical order**
** posting #2 shows the p/n's in alphabetical order**
When you click the bold link (p/n) you will get access to the pdf file.
The database is far from being complete; just give me some time to do more research and add the info to the database.
Any addition from your side is more than welcome, just let me know in this thread.
Kind regards,
FXD2003Rider
numerical.....
16550-04 ...cylinder kit big bore SE mud 9-17-09
17378-98 ...Screamin' Eagle® Roller Rocker Arms (fits '84-'99 Evolution® 1340-equipped models, '86-later XL and XR models and '99-later Twin Cam-equipped models. Modification is required on Twin Cam rocker™ covers.) (added 10-31-2009) contribution of: wireguided
17675-01B ...Screamin' Eagle® Forged Rocker Supports for Twin Cam Models (fits '99-later Twin Cam equipped models) (added 10-31-2009) contribution of: wireguided
17997-99A ...pushrods adjustable mud 9-14-09
18096-00A ...pushrod covers mud 9-14-09
18404-08 ...high performance quick-install adjustable pushrods (added 10-30-2009) contribution of: wireguided
25282-07 ...cam support plate mud 9-13-09
25284-08 ...hybrid cam plate and high flow oil pump kit (added 10-30-2009)
26151-07 ...Premium Oil Cooler Kit for Dyna® Models (Fits '06-later Dyna® models (except FXDSE/2, FXDFSE and California models). Does not fit with Front Spoiler Kits or Definitive5™ Filtration System Kits. Fits with all H-D® Engine Guards.) (added 11-08-2009)
27505-09 ...Screamin' Eagle 110 cubic inch stage I kit (fits '09 FXDF models) (added 10-30-2009)
29098-09 ...SE heavy breather performance air cleaner kit (added 09-19-2009)
29299-08 ...SE heavy breather performance air cleaner kit (added 09-19-2009)
31705-04 ...dyna chrome coil cover kit (fits carburated versions) (added 10-26-2009) contribution of: 2007fxdc
31709-04 ...dyna chrome coil cover kit (fits EFI versions) (added 10-26-2009) contribution of: 2007fxdc
37970-03A ...clutch SE race mud 9-14-09
40063-05A ...automatic primary chain tensioner (added 09-15-2009)
40274-08 ...big twin compensator mud 9-13-09
43768-06 ...wide tire kit mud 9-17-09
43911-95 ...head bolt covers
44531-04 ...dual disk brake kit (will fit '04 and later FXDI and FXDLI models) (added 04-19-2010)
44090-00 ...dual disc brake kit (will fit on '88-later XL, FXR and FXD models) (added Jan. 27-2010)
45023-02 ...triple tree
45075-08 ...chrome hand control lever kit Fits '08-later Dyna® and Softail® models (added Jan. 01-2010)
45075-07 ...chrome hand control lever kit Fits '96-'03 XL models and '96-'07 Dyna®, Softail® and Touring models. (Does not fit Police models, VRSC™ models, or models equipped with hydraulic clutch.)(added Jan. 01-2010)
45740-07 ...steering head washer kit (all 2006-2007 Dyna and 2008 and earleir FXDWG models) (added 11-06-2009)
46193-99 ...fork brace 39-41mm mud 9-14-09
46586-06 ...dyna chrome fork slider kit '06 and later (not for FXDWG, FXDF, FXDFSE & FXDSE/2) (added 10-17-2009)
46589-06 ...dyna fxdwg chrome fork slider kit (added 10-17-2009)
46595-06 ...fork brace 49mm mud 9-14-09
46646-05 ...brake rotor hardware kit (front) mud 9-18-09
48439-00B ...dyna chrome swingarm ('00 - '05 models) added 10-30-2009
48458-06 ...dyna chrome swingarm ('06 - '09 models) (added 10-30-2009) contribution of: wireguided
49021-09 ...dyna fwd control kit gloss black '06-later models (added 09-20-2009)
49080-03A ...dyna fwd control kit chrome '03-'05 models (added 09-20-2009)
49080-06A ...dyna fwd control kit chrome '06-later models (added 09-20-2009)
49279-06 ...dyna passenger footboard support kit (added 09-16-2009)
50357-04 ...swept-wing grooved passenger footboard kit (added 09-16-2009)
50451-09 ...mini footboard kit (added 10-21-2009)
50601-01 ...Dyna Floorboard kit (added 09-14-2009) kit is obsolete; individual p/n's still available!
27-0920 ... Substitute by V-Twin Mfg(added 02-12-2010)
53527-95A ...dyna docking hardware (added 09-25-2009)
53961-06 ...dyna docking hardware kit (added 09-19-2009) contribution of ackman1968
53964-06 ...FXWG docking hardware kit (added 09-19-2009) contribution of sanlyn
53968-06 ...directional relocation kit (added 09-19-2009) contribution of ackman1968
55975-08A...street slammer handlebar kit (added 17-09-2009)
55977-09 ...fatbob handlebar kit mud 9-13-09
56165-03 ...handlebar polyurethane riser bushing kit (added 09-27-2009)
56290-05 ...deluxe pullback riser and clamp kit (added 10-11-2009)
56679-02 ...100th Anniversary handlebar grips (added 11-19-2009)
56916-07 ...handlebar riser kit fatbob mud 9-17-09
57340-08 ...detachable windshield and quick-clamp docking kit 49mm forks (added 10-03-2009)
57716-01 ...compact replacement windshield kit
58006-87B ...windshield kit 39mm forks (added 10-05-2009)
58006-87C ...windshield kit 39mm forks (added 10-05-2009)
58042-04 ... dyna front spoiler, painted (added 10-16-2009)
58042-08... dyna glide front spoiler kit (added 10-17-2009)
58043-04 ... dyna front spoiler, chrome (added 10-16-2009)
58063-04 ...detachable windshield kit 39mm forks (added 10-03-2009)
58742-05 ...turn signal relocation kit (added 09-22-2009) (fits ’93-’05 FXDWG, ’86-later FXST, FXSTC, FXSTB, and ’00-’07 FXSTD models)
59802-05 ...quick release detachable windshield kit 41mm forks (added 10-03-2009)
60215-06 ...layback license plate and turn signal relocation kit (added 09-30-2009)
60747-01 ...dyna chrome inner primary cover (fits '01-'05 FXDWG models) (added 10-26-2009)[/color] contribution of: wireguided
60751-01 ...dyna chrome inner primary cover (fits '01-'05 Dyna® models except FXDWG) (added 10-26-2009)[/color] contribution of: wireguided
60794-06B ...dyna chrome inner primary cover (fits '06-later Dyna® models (except FXDWG, FXDSE/2, FXDFSE and FXDF with Forward Foot Controls) (added 10-26-2009) contribution of: wireguided
60792-06B ...dyna chrome inner primary cover (fits '06-later FXDWG, FXDSE/2, FXDFSE/2 and '07-later Softail® models (except FXCW, FXCWC, and '09 FXSTSSE3). Also fits '08-later FXDF models with Forward Foot Controls) (added 10-26-2009)[/color] contribution of: wireguided
62818-06C ...flush-mount led fuel gauge and gas cap kit (added 09-15-2009)
62974-09 ....lcd oil temperature/level dipstick (added 10-11-2009)
67224-04 ...tachometer kit mud 9-13-09
68227-09 ...dyna rear turn signal relocation kit FXDB '09- later (added 09-30-2009)
68544-10 ...dyna rear stop/tail/turn signal relocatioon kit (added 10-05-2009) contribution of billjoat
68546-09 ...tribar led tail light kit (added 09-19-2009) contribution of sanlyn
68564-06 ...front turn signal relocation kit (added 09-22-2009) (fits ’06-’07 Dyna models (except FXDSE/2))
68593-06 ...5 3/4" bullet headlamp kit (added 10-12-2009)
68718-02 ...fxdwg turn signal relocation kit '02 - later (added 09-30-2009)
68732-02A ...rear turn signal relocation bar (fits domestic motorcycles) (added 09-30-2009)
68733-02A ...rear turn signal relocation bar (fits international (HDI) motorcycles) (added 09-30-2009)
68953-04 ....Mini tach gauge kit (added 01-17-2010) click for fitment info
68986-04 ....Mini tach gauge kit (added 01-17-2010)
69284-05 ...Chrome auxiliary lamp kit (XL & FXD models) (added 09-19-2009)
69285-05 ...Chrome auxiliary lamp kit (FXDWG models) (added 09-19-2009)
69433-08 ...turn signal relocation kit (added 09-22-2009) (fits ’08-later Dyna models)
69820-06 ...narrow mountingkit for rear turn signals (added 12-12-2009)
69851-06 ...4 1/2" bullet headlamp kit (added 10-12-2009)
70222-96B ...chrome switch housing kit (added 09-17-2009)
74556-09 ...speedo/tacho combination- nostalgic face (added 09-13-2009)
74665-04 ...dyna voltage regulator kit (2004 through 2005 FXDL/I & FXDWG/I) (added 10-26-2009) contribution of: 2007fxdc
74667-06 ...dyna voltage regulator kit (2006 and later Dyna models) (added 10-26-2009) contribution of: 2007fxdc
75051-08 ...LED fuel gauge kit, bar & shield (ad 09-18-2009)
75095-05A ...LED fuel gauge kit, skull (Fits '04-'08 FXDB, FXDL, FXD35, FXDWG and FXDF models, '07-'08 FXDC models) (added 11-08-2009)
75098-08 ...LED fuel gauge kit, skull (ad 09-18-2009)
75133-99 ...oil pressure gauge kit mud 9-13-09
75242-08 ...LED fuel gauge kit, smooth (ad 09-18-2009)
80061-00 ...muffler kit mud 9-18-09
90181-08 ...dyna detachable saddlebags (added 09-22-2009)
91558-01A ...remote-control garage-door opener kit (both transmitter & receiver) (added 09-17-2009)
91561-01 ...remote-control garage-door opener transmitter kit (added 09-17-2009)
91562-01 ...remote-control garage-door opener receiver kit (added 09-17-2009)
98965-99 ...lift adapters mud 9-13-09
Kind regards,
FXD2003Rider
numerical.....
Last edited by FXD2003Rider; 04-19-2010 at 03:24 PM. Reason: synchronized with posting in Dyna Forum
current database page 2
Kind regards,
FXD2003Rider
alphabetical.....
100th Anniversary handlebar grips... 56679-02 (added 11-19-2009)
brake rotor hardware kit (front)... 46646-05 mud 9-18-09
bullet headlamp kit 4 1/2"... 69851-06 (added 10-12-2009)
bullet headlamp kit 5 3/4"... 68593-06 (added 10-12-2009)
cam support plate... 25282-07 mud 9-13-09
chain tensioner (primary) automatic ... 40063-05A (added 09-15-2009)
chrome auxiliary lamp kit (XL & FXD models)... 69284-05 (added 09-19-2009)
chrome auxiliary lamp kit (FXDWG models)... 69285-05 (added 09-19-2009)
chrome hand control lever kit... 45075-08 Fits '08-later Dyna® and Softail® models (added Jan. 01-2010)
chrome hand control lever kit... 45075-07 Fits '96-'03 XL models and '96-'07 Dyna®, Softail® and Touring models. (Does not fit Police models, VRSC™ models, or models equipped with hydraulic clutch.)(added Jan. 01-2010)
chrome switch housing kit ...70222-96B (added 09-17-2009)
clutch SE race... 37970-03A mud 9-14-09
compensator SE... 40274-08 9-13-09 mud
cylinder kit big bore SE... 16550-04 mud 9-17-09
deluxe pullback riser and clamp kit... 56290-05 (added 10-11-2009)
detachable windshield and quick-clamp docking kit 49mm forks... 57340-08 (added 10-03-2009)
detachable windshield kit 39mm forks... 58063-04 (added 10-03-2009)
directional relocation kit... 53968-06 (added 09-19-2009) contribution of: ackman1968
dual disc brake kit... 44090-00 (will fit on '88-later XL, FXR and FXD models) (added Jan. 27-2010)
dual disk brake kit... 44531-04 (will fit '04 and later FXDI and FXDLI models) (added 04-19-2010)
dyna chrome coil cover kit (fits carburated versions)... 31705-04 (added 10-26-2009) contribution of: 2007fxdc
dyna chrome coil cover kit (fits EFI versions)... 31709-04 (added 10-26-2009) contribution of: 2007fxdc
dyna chrome fork slider kit '06 and later (not for FXDWG, FXDF, FXDFSE & FXDSE/2)... 46586-06 (added 10-17-2009)
dyna fxdwg chrome fork slider kit '06 and later... 46589-06 (added 10-17-2009)
dyna chrome inner primary cover... 60794-06B (fits '06-later Dyna® models (except FXDWG, FXDSE/2, FXDFSE and FXDF with Forward Foot Controls) (added 10-26-2009) contribution of: wireguided
dyna chrome inner primary cover... 60792-06B (fits '06-later FXDWG, FXDSE/2, FXDFSE/2 and '07-later Softail® models (except FXCW, FXCWC, and '09 FXSTSSE3). Also fits '08-later FXDF models with Forward Foot Controls) (added 10-26-2009) contribution of: wireguided
dyna chrome inner primary cover... 60747-01 (fits '01-'05 FXDWG models) (added 10-26-2009) contribution of: wireguided
dyna chrome inner primary cover... 60751-01 (fits '01-'05 Dyna® models except FXDWG) (added 10-26-2009) contribution of: wireguided
dyna chrome swingarm ('00 - '05 models)... 48439-00B (added 10-30-2009)
dyna chrome swingarm (06 -''09 models)... 48458-06 (added 10-30-2009) contribution of: wireguided
dyna detachable saddlebags... 90181-08 (added 09-22-2009)
dyna docking hardware... 53527-95A (added 09-25-2009)
dyna docking hardware kit... 53961-06 (added 09-19-2009) contribution of: ackman1968
dyna front spoiler chrome... 58043-04 (added 10-16-2009)
dyna front spoiler painted... 58042-04 (added 10-16-2009)
dyna fwd control kit chrome '03-'05 models... 49080-03A (added 09-20-2009)
dyna fwd control kit chrome '06-later models... 49080-06A (added 09-20-2009)
dyna fwd control kit gloss black '06-later models... 49021-09 (added 09-20-2009)
dyna glide front poiler kit... 58042-08 (added 10-17-2009)
dyna rear stop/tail/turn signal relocatioon kit... 68544-10 (added 10-05-2009) contribution of: billjoat
dyna rear turn signal relocation kit FXDB '09- later... 68227-09 (added 09-30-2009)
dyna voltage regulator kit (2004 through 2005 FXDL/I & FXDWG/I) 74665-04 (added 10-26-2009) contribution of: 2007fxdc
dyna voltage regulator kit (2006 and later Dyna models) 74667-06 (added 10-26-2009) contribution of: 2007fxdc
Floorboard Kit Dyna ... 50601-01 (added 09-14-2009) kit is obsolete; individual p/n's still available!
Substitute by V-Twin Mfg ... p/n 27-0920 (added 02-12-2010)
footboard support kit (passenger) dyna... 49279-06 (added 09-16-2009)
footboard kit (passenger) swept-wing grooved ... 50357-04 (added 09-16-2009)
flush-mount led fuel gauge and gas cap kit... 62818-06C (added 09-15-2009)
fork brace 39-41mm... 46193-99 mud 9-14-09
fork brace 49mm... 46595-06 9-14-09 mud
FXWG docking hardware kit... 53964-06 (added 09-19-2009) contribution of: sanlyn
fxdwg turn signal relocation kit '02 - later... 68718-02 (added 09-30-2009)
handlebar kit fatbob... 55977-09 9-13-09 mud
handlebar polyurethane riser bushing kit... 56165-03 (added 09-27-2009)
handlebar riser kit fatbob... 56916-07 mud 9-17-09
head bolt covers... 43911-95
high performance quick-install adjustable pushrods... 18404-08 (added 10-30-2009) contribution of: wireguided
hybrid cam plate and high flow oil pump kit... 25284-08 (added 10-30-20090
layback license plate and turn signal relocation kit... 60215-06 (added 09-30-2009)
lcd oil temperature/level dipstick... 62974-09 (added 10-11-2009)
led fuel kit gauges, bar & shield ...75051-08 (added 09-16-2009)
led fuel gauge kit, skull (Fits '04-'08 FXDB, FXDL, FXD35, FXDWG and FXDF models, '07-'08 FXDC models) ...75095-05A ... (added 11-08-2009)
led fuel kit gauges, skull ...75098-08 (added 09-16-2009)
led fuel kit gauges, smooth ...75242-08 (added 09-16-2009)
lift adapters... 98965-99 9-13-09 mud
mini footboard kit... 50451-09 (added 10-21-2009)
mini tach gauge kit... 68953-04 (added 01-17-2009) click for fitment info
mini tach gauge kit... 68986-04 (added 01-17-2009)
muffler kit... 80061-00 mud 9-18-09
narrow mounting kit for rearurn signals... 69820-06 (added 12-12-2009)
oil pressure gauge kit... 75133-99 9-13-09 mud
Premium Oil Cooler Kit for Dyna® Models (Fits '06-later Dyna® models (except FXDSE/2, FXDFSE and California models). Does not fit with Front Spoiler Kits or Definitive5™ Filtration System Kits. Fits with all H-D® Engine Guards.)... 26151-07 (added 11-08-2009)
pushrods adjustable... 17997-99A mud 9-14-09
pushrod covers... 18096-00A mud 9-14-09
quick release detachable windshield kit 41mm forks... 59802-05 (added 10-03-2009)
rear turn signal relocation bar (fits domestic motorcycles)... 68732-02A (added 09-30-2009)
rear turn signal relocation bar (fits international (HDI) motorcycles)... 68733-02A (added 09-30-2009)
remote-control garage-door opener kit (both transmitter & receiver)... 91558-01A (added 09-17-2009)
remote-control garage-door opener transmitter kit... 91561-01 (added 09-17-2009)
remote-control garage-door opener receiver kit... 91562-01 (added 09-17-2009)
SE heavy breather performance air cleaner kit... 29098-09 (added 09-19-2009)
SE heavy breather performance air cleaner kit... 29299-08 (added 09-19-2009)
SE 110 cubic inch stage I kit for EFI models (fits '09 FXDF models)... 27505-09 (added 10-30-20090
Screamin' Eagle® Forged Rocker Supports for Twin Cam Models (fits '99-later Twin Cam equipped models)... 17675-01B (added 10-31-2009) contribution of: wireguided
Screamin' Eagle® Roller Rocker Arms (fits '84-'99 Evolution® 1340-equipped models, '86-later XL and XR models and '99-later Twin Cam-equipped models. Modification is required on Twin Cam rocker™ covers.) ... 17378-98 (added 10-31-2009) contribution of: wireguided
speedo/tacho combination- nostalgic face... 74556-09 (added 09-13-2009)
steering head washer kit (all 2006-2007 Dyna and 2008 and earlier FXDWG models)... 45740-07 (added 11-06-2009)
street slammer handlebar kit ...55975-08A (added 17-09-2009)
tachometer kit... 67224-04 mud 9-13-09
tribar led tail light kit... 68546-09 (added 09-19-2009) contribution of sanlyn
triple tree... 45023-02
turn signal relocation kit (fits ’93-’05 FXDWG, ’86-later FXST, FXSTC, FXSTB, and ’00-’07 FXSTD models)... 58742-05 (added 09-22-2009)
turn signal relocation kit (fits ’06-’07 Dyna models (except FXDSE/2))... 68564-06 (added 09-22-2009)
turn signal relocation kit (fits ’08-later Dyna models)... 69433-08 (added 09-22-2009)
wide tire kit... 43768-06 mud 9-17-09
windshield kit 39mm forks... 58006-87B (added 10-05-2009)
windshield kit 39mm forks... 58006-87C (added 10-05-2009)
windshield kit compact replacement... 57716-01
Kind regards,
FXD2003Rider
alphabetical.....
Last edited by FXD2003Rider; 04-19-2010 at 03:26 PM. Reason: synchronized with posting in Dyna Forum
current metric sizes database back-up page
This is a back-up copy; synchronized 11-06-2009
click HERE for ***dyna models metric sizes database thread***
Occasionally forum members have questions on what size of metric tools they have to use on the metric bolts and nuts mounted on their dyna model.
Info on this subject is scattered in the forum now.
Purpose of this thread is to gather this info and put it in an easy accessable database.
Any suggestions and additional info from your side is appreciated. Just add a posting to the thread and I'll process the info into the database.
Thanks in advance,
___________
FXD2003Rider
2003 FXD
battery terminal bolts p/n 4312 (M6 X 1.0 X 12 flange head)..................... 10mm 6-point socket added 10-19-2009
clutch spring / pressure plate bolt M6 X 1" X 16 hex head, p/n 2980 .......... 10mm 6-point wrench/socket (added 11-04-2009) contribution of: mud (link)
fork tube cap p/n 45996-87 .................................................. ............. 35mm 6-point socket
35mm forks cap nut socket tool link
front axle nut p/n 7956 .................................................. ................... 19mm 6-point socket
front brake caliper lower mounting bolt p/n 44160-00 ............................... 10mm 12-point socket
front brake caliper upper mounting bolt p/n 44163-00 .............................. 10mm 12-point socket
front brake master cylinder fitting single disk p/n 41739-84A ..................... 11mm 12-point socket
horn/horn bracket nut M6, p/n 7495 .................................................. .. 10mm 6-point hex wrench/socket (added 11-04-2009) (link)
rear axle castle nut p/n 7987 .................................................. ........... 24mm 6-point socket
rear brake caliper bridge bolt p/n 44177-00 ............................................ 10mm 12-point socket
starter motor section:
NUT, flange M8, p/n 3403 .................................................. ................ 13mm 6-point hex wrench/socket (added 11-04-2009) (link)
BOLT, starter M5, p/n 928 .................................................. ................. 8mm 6-point hex wrench/socket (added 11-04-2009) (link)
SCREW w/ O-Ring M4, p/n 929A .................................................. ......... 7mm 6-point hex wrench/socket (added 11-04-2009) (link)
2005 models
front fork seat pipe screws p/n???? .................................................. . 12mm 6-point allen wrench added 10-20-2009 contribution of: jmpancoast (link) &
FastHarley (link)
2006 All models
2007 FXDC
fork tube cap p/n 45996-87 .................................................. ............. 35mm 6-point socket contribution of: 2007fxdc
fork tube spring asembly socket head bolt
p/n 46614-06 Bolt M14 x 1.25 x 30socket head ....................................... 5mm 6-point hex bit added 10-20-2009 contribution of: thedonthere (link)
front axle clamp hex button head bolts p/n 4042 ..................................... 5mm 6-point hex bit added 10-20-2009 contribution of: thedonthere (link)
as a companion to this 4042 bolt we have p/n 7062 metric lockwasher M8.4 x 13 x 1.2 (added 11-06-2009) contribution of: mud
rear axle nut p/n 8039 .................................................. .................... 28mm 6-point socket contribution of: rdondes (link) & SC-Longhair
2008 models
battery terminal bolts (flange head) p/n 4312c ...................................... 10mm 6-point socket added 10-19-2009 contribution of: frogg (link) & BBerck
Hex screws to the fork axle holder p/n4042 ............................................ 5mm 6-point socket contribution of: BBerck
jam nut on the clutch pack is a M17 bolt p/n??? ................................... 17mm 6-point socket contribution of: maddghost (link)
Fatob rear axle nut .................................................. ........................ 36mm 6-point socket contribution of: archergodwin (link)
rear axel nut p/n's:
7813A axle nut for WG, SGC, SB and LR if has spoke wheels contribution of: BBerck
8020 axle nut for SG, FB and LR with mag wheels contribution of: BBerck
FXDC rear axle hex head p/n??? .................................................. ...... 28mm 6-point socket contribution of: archergodwin (link)
Showa forks
fork tube (l&r) damper (socket head) screw p/n 46614-06 ....................... 12mm 6-point socket head contribution of: 2007fxdc; SC-Longhair; BBerck
1/2" Impact Socket head 12 mm metric Hex Driver tool link .................................................. ....... contribution of: SC-Longhair
Thanks in advance,
___________
FXD2003Rider
2003 FXD
2005 models
FastHarley (link)
2006 All models
2007 FXDC
2008 models
Showa forks
Last edited by FXD2003Rider; 01-01-2010 at 08:03 AM. Reason: synchronized with posting in Dyna Forum
initial database; content is out-dated; see page 1 & 2
Info at this page is out-dated; content had to be split into two pages (see page 1 & 2)
The first part shows the p/n's in numerical order, the second part shows the parts in alphabetical order.
Kind regards,
FXD2003Rider
numerical.....
16550-04 ...cylinder kit big bore SE m 9-17-09
alphabetical.....
brake rotor hardware kit (front)... 46646-05 m 9-18-09
Kind regards,
FXD2003Rider
numerical.....
alphabetical.....
Last edited by FXD2003Rider; 02-14-2010 at 05:21 AM. Reason: Content synchronized with post in Dyna forum by FXD2003Rider 10-16-2009
Here's how to paste images into a post:
Like yoy I use a free account at photobucket.com to copy/paste pics into a post.
You have to upload your pictures to your photobucket account first, using the 800 X 600 re-sizing option in photobucket.
When you want to paste a picture in a post click the "insert link" on top of the Reply to Thread box.
A message comes up and you have to allow the pop-up.
Now go to your album at photobucket, put your mouse on the pic you want to insert and a little properties screen pops up. Click on the lower img code box and copy this img code.
Now go to your post, click the insert link and paste the img code into the box and click OK (see below)
Preview your post and check if the picture is not to large.
Let me know if you want some more help.
FXD2003Rider
FXD2003Rider
***Dyna Models Wiring Diagram Links Index***
click HERE for ***Dyna Models Wiring Diagram Links Index thread***
unknown year rear taillight wiring diagram
posted by: dawg 01-20-2010
1982 and 1983 FXR/FXRS wiring diagram
posted by: dope_man_21 02-09-2010
1986 - 1990 FXR wiring diagram
posted by: chendave2003 12-31-2008
1999 Dyna models wiring diagram -horn and instruments-
contribution by email of: kpolak 02-12-2010
2003 Dyna Glide models wiring diagram
posted by: FXD2003Rider 01-22-2010
2003 Dyna Glide fuel level sending unit wiring diagram
posted by: FXD2003Rider 02-05-2010
2006 All Dyna Dom. and Int. (Except FXDWG, FXD35) Starting Circuit
posted by: mud 01-01-2009
2007 Dyna models (except FXDWG, FXDC) wiring diagram
posted by: skip3406 09-08-2009
2007 Dyna taillight wiring diagram
posted by: mud 12-26-2007
air horn hookup wiring diagram
posted by: Ctac 01-10-2010
fog lights wiring diagram
posted by: FXD2003Rider 08-16-2009
*HOW TO * under fifty bux* Index
Important user directions:
The page # link only works satisfactory if your user settings in your
USERCP / Settings & Options / Edit Options under Thread Display Options are set to:
Thread Display Mode: Linear-Oldest First
Number of Posts to Show Per Page: Show 40 Posts Per Page
Now scroll down to the bottom of the page and push Save Changes!
page 26
post# 1001 …… brake bleeder (part 2) ................................ SC-Longhair
post# 1009 …… internal bar wiring ....................................... dklozik
post# 1010 …… choke **** ................................................. chengdave2003
post# 1010 …… sissy bar/back rest bracket ......................... chengdave2003
post# 1013 …… memphis shades free mod ............................ SuperFastGlide
post# 1014 …… temporary pillion ......................................... slomotion
post# 1015 …… leather preparation ..................................... JRK5892
post# 1018 …… can crusher ................................................ mud
post# 1022 …… black out spokes ......................................... JRK5892
post# 1024 …… inspection sticker relocation ......................... Slipstrm
post# 1025 …… side mount plate tail light ............................. Slipstrm
post# 1029 …… touch up paint ............................................. buellrider76
post# 1030 …… rear running lights (part 1) ........................... buellrider76
post# 1031 …… mini tank bra .............................................. chengdave2003
post# 1033 …… rear running lights (part 2) ........................... Citoriplus
page 27
post# 1044 …… rear running lights (part 3) ........................... Citoriplus
post# 1045 …… J&S jack improvements ............................... mud
post# 1046 …… 12 Volt plug on the bike ................................ dklozik
post# 1053 …… fork stem nut clock ..................................... chengdave2003
post# 1057 …… stripping and polishing covers ........................ mud
post# 1062 …… polishing paluminium pieces ........................... RudeDog
post# 1065 …… tank lift .................................................. . mud
post# 1069 …… quick release fuel valve ................................ lee
post# 1075 …… rocker box wrinkle black out ........................ boutellepc
page 28
post# 1081 …… video camera mount ..................................... mud
post# 1085 …… high beam garage door opener ...................... Streets of Fire
post# 1089 …… video upload to YouTube .............................. Vetto
post# 1091 …… molex connector poking tool .......................... mud
post# 1092 …… AMP fitting release tool ............................... mud
post# 1093 …… Deutsch fitting crimper ............................... mud
post# 1094 …… wiring tail light ............................................ mud
post# 1096 …… old school tunable baffles ............................ vetto
post# 1097 …… rocker c seat modification ............................ robo01
post# 1098 …… wiring diagram for 1986 - 1990 FXR .............. chengdave2003
post# 1105 …… 2006 Dyna starting circuit wiring diagram ....... mud
post# 1109 …… dice gear shift ............................................ lee
post# 1111 …… dice wire separators ................................... lee/mud
post# 1112 …… hardwood gear shift .................................... lee
post# 1118 …… garage door opener ..................................... Hickey
page 29
post# 1123 …… license plate mount hole covers ..................... JaronB
post# 1126 …… cable & wire wrap ....................................... JRK5892
post# 1129 …… cable & wire wrap ....................................... Citoriplus
post# 1130 …… rear turn signal snug mounting ....................... OrdinaryJoe
post# 1131 …… QD windsh. reduced buffeting modification ..... OsoFat
post# 1138 …… riser extensions ......................................... Grind
post# 1139 …… wooden bike jack/center stand ..................... condition001
post# 1140 …… '07 FXD ignition switch relocation (part 1) ...... Slipstrm
post# 1146 …… '07 FXD ignition switch relocation (part 2) ...... Slipstrm
post# 1148 …… 1.5 inch riser extensions ............................... crapgame
post# 1154 …… chrome oil line & cable wraps ........................ JRK5892
post# 1155 …… wire wraps ................................................. Citoriplus
post# 1157 …… finishing wire wraps ..................................... Citoriplus
post# 1159 …… connecting floating charger .......................... JRK5892
post# 1160 …… shifter linkage upgrade (part 1) .................... HB
page 26
page 27
page 28
page 29
