New to the darkside, belt rubbing sidewall
in your original post you said you're only running 30 psi... most of us with 205/55 16 are at 38 psi or higher ... i started at 40 psi and work down to 38 psi ... less air pressure allows the side to squat down ( read bulge )... it takes awhile for the side wall to break in.. also it's damn cold up there right now... try setting to 40 psi and insure the tire is aligned properly ... hope this helps
Gunny out
Gunny out
ricopaces
11-29-2009 11:07 PM
