Looking to move to the darkside
Interesting. I'm assuming that its fine in the summer? How long have you had it? Mileage? Mount it yourself?
Alpin
The tire is fine in the summer. I've got about 10K on it and it looks good. I think it will out do the SP5000. I got 19.5 out of it and hope to get closer to 25K out of the Alpin.
I can't get more than 13K out of a stock rear.
Once you try that, put a Bridgestone BattleAx on the front. Only get the one that says "For Rear use only". My last one cost $105 delivered and they last for over 20K. Handle very nicely too.
All was good until my speed hit 55 mph and above. At this point the trailer started wagging back and fourth. The lightly loaded trailer probably weighed about 400 lbs. and I was going to be hauling closer to 500 lbs. I tried increasing the speed. I tried changing the tongue weight by shifting the load. I tried different tire pressures on both the bike and trailer. I could not get rid of this dangerous wagging. Since I had had no problems towing the same trailer behind my 2004 Dyna Low Rider I figured that it was my car tire. I ordered a Metzler bike tire and my problem was instantly solved. The trailer tracked straight as an arrow.
Bottom Line: if towing a heavy trailer do not install a car tire because the side walls are too soft which produce a dangerous tail wagging problem.
The car tire I had used was a Michelin Primacy MXV4. I chose it because of it's long wear and it's claimed superior handling on wet pavement. Until I hooked up my trailer it was a wonderful riding tire at any speed. I am thinking about buying a used rear wheel so I can put it back on when I'm not towing.
This place is awesome!! I was at Walmart 2 weeks ago buying oil/filter and started looking at slim car tires to put on my 88 FLSTC, the new back tire I put on sat cost me 368$ from the dealership. I wonder if I can make one fit? I never pull a trailer, but do ride 2 up. Tires for my crown Vic only cost 88$ a piece, motorcycle tires and other parts are a rip off.
Good idea
I bought a new takeoff set of wheels. I love to have two new mounted tires waiting for me. It's really nice to be able to take off across country at any time without having to bring a wheel in to mount a new tire. Also, it makes it where I can change my own tires, because I have plenty of time to do it.
There are a ton of reasons to have a spare wheel. If you do it, you'll love it.
In June of this year I had my local Yamaha dealer install a Michelin 205/55-16 R car tire on my 2009 Street Glide. I was preparing for a 7600 miles bike trip and was pulling an Aspen Classic tent trailer. About a week before leaving I thought I should hook up my trailer and do a dry run just to see how it all worked together.
I put a car tire on my last bike specifically for towing my time out camper. No problems. I will put a car tire on my new bike specifically for the increased load capacity of the ct. I never experienced any issues on my last bike, certainly don't expect any on this bike.
